Last reset from system-reset
acbenny
Hi expert,
Anyone know what is the reason of "Last reset from system-reset" ? is it the router automatically reboot due to some reason ?
sourabhagarwal
Level 4
Level 4
can you share "show version" output of the device?
mheusinger
Level 10
Level 10
which system did give you this message?
In CatOS there is a command "reset-switch"
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00803d6d3c.html#wp1031473
So in general this would be caused by the command above or through "reload" in an IOS based Catalyst.
Hope this helps! Please use the rating system.
Regards, Martin
