Latest IOS For Switches Series 3560.
Amit Thakkar
HI,
Looking for Information about Latest IOS Available for switch Series 3560, Guide the latest IOS sopprted Features Specification And Also Guide the Switch Minimum Hardware capacity Require to upgrade with the latest IOS.
     Thanx in Advance
For Your Valuable Responce.
Latchum Naidu
Hi Amit,
All Catalyst switches currently run some variant of the IOS 12.2 line. The minor revision number in parentheses is the important part. For example, 12.2(44)SE2. You can also use Cisco's feature navigator for the same.
Look at the below release notes will give you clear picture.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/15.0_1_se/release/notes/OL25301.html
Please rate the helpfull posts.
Naidu.
Latchum Naidu
Hi Amit,
Naidu.
Thanks Naidu
This Doc, is very IMP for me,,,,,,,,,,
