lawful-intercept (Cisco Router)
Youssef_Joe
Gents , Hope you have good day
i am using 3800 s router , i have erase all configuration and get it back to factory default by using command #erase nvram
after i put the new configuration on it and try to save the configuration i got error message : ( mgcp_cf g-commands: nvgen lawful-intercept: should not happen) , i don't know where this error coming from
can you please help ?
thanks
yegorgr
What is your IOS version? See if you are affected: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsq16200/?rfs=iqvred
Another question, what is the command that you are using to save the configuration?
Thank you.
