Layer 1 or Layer 8 problem?
Patrick Evans
So i am studying for my CCNA and i have a problem getting a serial link to work.  I have tried 2 cables and re-seating the serial module. Have i done something wrong or is it broken?  I have switched loopback on both side and the line protocol doesnt come back up on the DTE end.
Here is the DTE end:
ICND1-RTR2#sho int s1/0
Serial1/0 is up, line protocol is down
  Hardware is CD2430 in sync mode
  Internet address is 192.168.11.1/31
  MTU 1500 bytes, BW 128 Kbit, DLY 20000 usec,
     reliability 140/255, txload 1/255, rxload 1/255
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input never, output 00:00:01, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     2007826 input errors, 0 CRC, 0 frame, 2007826 overrun, 0 ignored, 0 abort
     271 packets output, 10465 bytes, 270 underruns
     270 output errors, 0 collisions, 90 interface resets
     34 carrier tr
*Mar  1 00:43:31.873: Serial1/0: HDLC myseq 53, mineseen 0, yourseen 0, line down
*Mar  1 00:43:32.943: Serial1/0: attempting to restart
*Mar  1 00:43:32.943: Serial0, cd2430_sync_mode_init
*Mar  1 00:43:32.943: CIRRUS(0): Deasserting DTR
*Mar  1 00:43:32.943: CIRRUS(0): Deasserting RTS
*Mar  1 00:43:32.943: CIRRUS(0): Reset from 0x80392624
*Mar  1 00:43:32.947: CIRRUS(0): Asserting DTR
*Mar  1 00:43:32.947: CIRRUS(0): Asserting RTS ansitions
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
And here is the DCE end:
ICND1-RTR1#sho int s0/0
Serial0/0 is up, line protocol is down
  Hardware is PowerQUICC Serial
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Last input 00:20:49, output 00:00:08, output hang never
     151 packets input, 11954 bytes, 0 no buffer
     Received 151 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     302 packets output, 17528 bytes, 0 underruns
     0 output errors, 0 collisions, 53 interface resets
     185 carrier transitions
ICND1-RTR1#
*Mar  1 00:45:20.307: Serial0/0: HDLC myseq 64, mineseen 0, yourseen 0, line dow
Cheers Guys.
8 Replies 8
paolo bevilacqua
OSI layer 8 is "political", so I don't think it applies here.
Hi Patrick,
This is a layer 2 issue at the most. I would invert the cable ends to check if he DTE is connected on the right side and the encapsulation you need for. Is it a back to back link?
Alessio
Ps: do not consider the political layer for your studies. They are only 7 if you consider the ISO/OSI stack model.
Hello
Is this a back to back connection? - if so
Disable keepsalives and provide clocking for the dce
Res
Paul
Kind Regards
Paul
Subeh Sharma
Patrick,
Please paste the serial interface configuration here.
Subeh
Patrick Evans
Hi Everyone.
It is a back to back link yes.  Below is the config for both Routers.
ICND1-RTR2#sho run int s1/0
Building configuration...
Current configuration : 101 bytes
interface Serial1/0
ip address 192.168.11.1 255.255.255.254
no fair-queue
clock rate 64000
end
ICND1-RTR1#sho run int s0/0
Current configuration : 109 bytes
interface Serial0/0
no ip address
ip nat inside
ip virtual-reassembly
no keepalive
no fair-queue
end
Thanks Patrick
Patrick,
1. Give clock rate command on RTR1 as it is the DCE
2. Configure an IP on RTR1 in the same subnet.
Subeh
Hi Subeh,
Thanks for getting back to me.
One thing that I though I put in my original post but missed is :
*Mar  1 00:03:56.559: PowerQUICC(0/0): DCD is down.
*Mar  1 00:03:56.559: PowerQUICC(0/0): DCD is up.
I changed the WIC 1T module and that solved that.  After i got the line up.  You were completely correct, I had forgotten to address the other interface on RTR1.  I have done that now and i can ping acccross the link.
Thanks to everyone that responded.
PS Alessio and Paulo, I come from an IT support background where layer 8 is generally used as "user" ?(in this case me)
Glad to know the issue has been resolved, Patrick!
Subeh
