Showing results forĀ
Search instead forĀ
Did you mean:Ā
Layer3 vs SVI
Johnson_Mo
team,
I have CAT 9300 set up with ISR 4331. I have  it connected via DIY "Diode connection." when I assign vlan 11 with ip 10.10.10.1/ as switch port access vlan 11 to the uplink interface of the 9300, traffic wont pass to 433. when I assign the ip directly to the interface, Mcast passes with no issue. any idea why?
thanks in advance
11 Replies 11
You face issue with only mcast ?
Or mcast and unicast ?
thanks for replying!
the issue is both.
the issue is that when I assign vlan 11 to the uplink if 9300, the interface does not pass anything, but when I convert it to layer3 with IP of vlan 11, it works fine.
Can i see the config of ISR interface
int tengi 1/1/1
switchport access vlan 11
switchport mode access
Not switch interface but isr router interface
MHM
interface gig 0/0/0
ip add 10.10.10.2 25.255.255.0
ip pim dense-mode
no negotiation auto
Nothing wrong until now
Show vlan
Check if vlan appear
Show ip interface breif
Check if the vlan SVI is up/up
MHM
vlan is shown and the SVI is up/up
I think it is IOS issue. I am using 17.9.3 now. when I switch to 16, it works fine.
Show interface | include line | address
Check if mac of this vlan is same for othet vlan
MHM
is not the same as other MAC addresses
