lcp negotiation issues
ccollins
I have a serial crossover cable between a Cisco 1700 and 2691 router connecting two CSU/DSU. The CD light is green and the interfaces are UP  and line protocol  Down. I am getting the following repeating error on both when running debug ppp nego:
Jul 18 17:47:11.355 EST: Se0/0:0 LCP: State is Listen
Jul 18 17:47:41.371 EST: Se0/0:0 LCP: Timeout: State Listen
Jul 18 17:47:41.371 EST: Se0/0:0 PPP: Authorization required
Jul 18 17:47:41.371 EST: Se0/0:0 LCP: O CONFREQ [Listen] id 153 len 10
Jul 18 17:47:41.371 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:43.387 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:43.387 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 154 len 10
Jul 18 17:47:43.387 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:45.403 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:45.403 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 155 len 10
Jul 18 17:47:45.403 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:47.419 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:47.419 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 156 len 10
Jul 18 17:47:47.419 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:49.435 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:49.435 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 157 len 10
Jul 18 17:47:49.435 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:51.451 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:51.451 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 158 len 10
Jul 18 17:47:51.451 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:53.467 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:53.467 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 159 len 10
Jul 18 17:47:53.467 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:55.483 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:55.483 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 160 len 10
Jul 18 17:47:55.483 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:57.499 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:57.499 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 161 len 10
Jul 18 17:47:57.499 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:47:59.515 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:47:59.515 EST: Se0/0:0 LCP: O CONFREQ [REQsent] id 162 len 10
Jul 18 17:47:59.515 EST: Se0/0:0 LCP:    MagicNumber 0x108A129B (0x0506108A129B)
Jul 18 17:48:01.531 EST: Se0/0:0 LCP: Timeout: State REQsent
Jul 18 17:48:01.531 EST: Se0/0:0 LCP: State is Listen
Jul 18 17:48:31.547 EST: Se0/0:0 LCP: Timeout: State Listen
Jul 18 17:48:31.547 EST: Se0/0:0 PPP: Authorization required
The configuration on the 2691 running 12.4 is:
controller T1 0/0
framing esf
linecode b8zs
channel-group 0 timeslots 24
interface Serial0/0:0
ip address 192.168.69.2 255.255.255.252
encapsulation ppp
The Configuration running on the 1700 running 12.3 is:
interface Serial0
ip address 192.168.69.1 255.255.255.252
encapsulation ppp
fair-queue
service-module t1 clock source internal
The crossover cable is:
1...4
2...5
4...1
5...2
1700:
do sho int se0
Serial0 is up, line protocol is down
  Hardware is PQUICC with Fractional T1 CSU/DSU
  Internet address is 192.168.69.1/30
  MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
  Encapsulation PPP, LCP REQsent, loopback not set
2691:
sho int se0/0:0
Serial0/0:0 is up, line protocol is down
  Hardware is GT96K Serial
  Internet address is 192.168.69.2/30
  MTU 1500 bytes, BW 56 Kbit/sec, DLY 20000 usec,
     reliability 198/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Listen, loopback not set
Why won't the the connection come ujp? Thank you for any help that you may be able to provide.
ccollins
Solved but not understood. The 1700 has a WIC 1DSU T1 module and the 2691 has a VWIC 2MFT-T1 module. I added a WIC 1DSU-T1 module in the 2691 and it works fine. Was the VWIC 2MFT-T1 broken? It looks different in the configuration could I have missed some configuration option? I may never know..
