LFI (virtual interface down/down)
mailaglady2
I am trying to configure LFI but my virtual interface is down, does anybody has basic working configs for me. below are my configs:-
interface Virtual-Template1
no ip address
ppp multilink
ppp multilink interleave
ppp multilink fragment delay 20
ip rtp reserve 2000 20 256
DUT_3825(config)#do sb
GigabitEthernet0/0 192.4.1.1 YES manual up up
GigabitEthernet0/1 155.239.247.103 YES NVRAM up up
Serial0/3/0 165.148.120.1 YES manual up up
Serial0/3/1 165.148.121.1 YES manual up up
NVI0 192.4.1.1 YES unset up up
Virtual-Access1 unassigned YES unset down down
Virtual-Template1 unassigned YES TFTP down down
Loopback0 1.1.1.1 YES NVRAM up up
Hello Lawrence,
>> Is authentication a must configure?
no but both sides need to agree on this
what is the PVC state
use sh frame-rel pvc
if it is fine you can
shut the interface
term mon
debug ppp neg
debug ppp auth
no shut serial interface
so you can see if PPP frames flow on the PVC
Hope to help
Giuseppe
6 Replies 6
Harold Ritter
Lawrence,
Is the virtual template applied to a physical interface/subinterface as suggested in the following document?
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcflfifr.html#wp1002095
Yes i have done it that as per the document you attached..
configs
class-map match-all cba
match access-group 100
policy-map abc
class cba
priority 48
interface Serial0/3/0
bandwidth 512
no ip address
encapsulation frame-relay
clock rate 8000000
frame-relay intf-type dce
interface Serial0/3/0.100 point-to-point
snmp trap link-status
frame-relay interface-dlci 100 ppp Virtual-Template1
class mlp
bandwidth 78
ip address 165.148.120.1 255.255.255.252
ppp multilink
service-policy output abc
map-class frame-relay mlp
frame-relay cir 64000
frame-relay bc 300
frame-relay be 0
access-list 100 permit udp any any precedence critical
DUT_3825#sh ip int br
GigabitEthernet0/0 192.4.1.1 YES NVRAM up up
Serial0/3/0 unassigned YES manual up up
Serial0/3/0.100 unassigned YES NVRAM up up
Serial0/3/1 unassigned YES NVRAM administratively down down
Virtual-Template1 165.148.120.1 YES manual down down
Virtual-Access2 165.148.120.1 YES TFTP up down
Hello Lawrence,
sorry for the basic question:
have you configured for PPP the other side at the remote end of the FR PVC ?
you can troubleshoot how PPP behaves using
debug ppp negotiation
debug ppp authentication
Hope to help
Giuseppe
no problem in most cases these basic questions do help a lot, Yes I have configured ppp on the other side, Is authentication a must configure?
Hello Lawrence,
shut the interface
term mon
debug ppp neg
debug ppp auth
Hope to help
Giuseppe
I am sorted now thanks, the problem here was the different dlci's that I configured.
