15956
Beginner
License Activation on 4500
HI all,
  I want to use this (entservices) its showing active but not in use how can i do that ?
CORE1#sh license summary
Index 0   Feature: entservices
          Period left: 1513 weeks 1 day
          License State: Active, Not in Use, EULA accepted
          License Count: Non-Counted
Index 1   Feature: ipbase
          Period left: 8 weeks 4 days
          License Type: Evaluation
          License State: Active, Not in Use, EULA not accepted
          License Priority: None
Index 2   Feature: lanbase
          Period left: 0 seconds
Index 3   Feature: internal_service
CORE1#sh license right-to-use
License Store: Primary License Storage
License Store: Dynamic License Storage
StoreIndex: 1 Feature: entservices  Version: 1.0
      License Type: PermanentRightToUse
StoreIndex: 3 Feature: ipbase  Version: 1.0
      License State: Inactive
CORE1#sh license all
StoreIndex: 0 Feature: entservices  Version: 1.0
        Evaluation total period: 8 weeks 4 days
        Evaluation period left: 8 weeks 3 days
      License Priority: Low
StoreIndex: 2 Feature: ipbase  Version: 1.0
        Evaluation period left: 8 weeks 4 days
CORE1#sh version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.04.02.SG RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 05-Sep-13 20:34 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010, 2012 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG5
CORE1 uptime is 1 day, 1 hour, 4 minutes
Uptime for this control processor is 1 day, 1 hour, 7 minutes
Running default software
Jawa Revision 7, Snowtrooper Revision 0x0.0x1C
Last reload reason: power-on
License Information for 'WS-X45-SUP7-E'
    License Level: lanbase   Type: Default. No valid license found.
    Next reboot license Level: lanbase
cisco WS-C4507R+E (MPC8572) processor (revision 10) with 2097152K/20480K bytes of memory.
Processor board ID FXS1650Q0US
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
8 Virtual Ethernet interfaces
144 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
CORE1#
5 REPLIES 5
Beginner
Hi ,
Hi ,
Please issue the below command to activate the ent feature.
Switch# license right-to-use activate entservices all acceptEULA
 reload.
and then check
Don't you have set it as the
Don't you have set it as the next license boot level before reload?
Switch(config)# license boot level entservices
Beginner
I didnt have to do that, just
I didnt have to do that, just:
license right-to-use activate entservices acceptEula
wr
reload
Enthusiast
Re: Don't you have set it as the
I had to do this.
I'm upgrading from single SUP6 entservices to dual SUP7.
after entering "license right-to-use activate entservices acceptEULA" and reload, using IOS-XE 3.8.8, I still have no licenses activated.
Switch#sh license all
StoreIndex: 4 Feature: lanbase Version: 1.0
Switch#
Switch#sh license right-to-use
Switch#
show license in-use returns nothing.
if it set :
Then entservices is activated but as Evaluation.
After a couple of reboot and tests I didn't manage to get the permanent entservices.
Any clue ?
Content for Community-Ad
July's Community Spotlight Awards
