License installation on cisco c1111-4P
JRGC
Hi there,
I'm trying to install a security license on my cisco 1111P,  I have a .lic file in the flash but when I try to install the router is not recognize the commands, "just accept license smart register idtoken"
Cisco IOS XE Software, Version 16.09.02
The lic file was send me from cisco
Somebody have a suggestion for install it?
Thank you in advance
6 Replies 6
Hope you are trying to register your smart licensing. Smart license require Smart account( account should be with the client domain name) and the license will be deposited in Smart account. you need to generate a token from Smart account and use the same on router.
go through the link to learn more.
https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-6/cisco_1100_series_swcfg_xe_16_6_x/cisco_1100_series_swcfg_xe_16_6_x_chapter_010011.html
How to Activate Cisco Smart Licensing Client
Enable Smart Licensing
Procedure
  Command or Action Purpose
Step 1
enable
Example:
Device> enable
Enables privileged EXEC mode.
  • Enter your password if prompted.
Step 2
configure terminal
Example:
Device# configure terminal
Enters global configuration mode.
Step 3
license smart enable
Example:
Device# license smart enable
Activates Smart Licensing on the device.
Note
When you enable Smart Licensing, the Cisco Software License (CSL) and all licensing calls pass through the Smart Agent.
For the ‘no’ case, if Smart Licensing is already registered, the Smart Agent performs the ”license smart deregister” operation that deactivates Smart Licensing.
Step 4
exit
Example:
Device# exit
Exits the global configuration mode.
Step 5
write memory
Example:
Device# write memory
Saves the running configuration to NVRAM.
Step 6
show license all
Example:
Device# show license all
(Optional) Displays summary information about all licenses.
Smart License Disable
Procedure
Step 1
enable
Example:
Device> enable
Step 2
configure terminal
Example:
Step 3
no license smart enable
Example:
Device(config)# no license smart enable
Deactivates Smart Licensing on the device.
Note
When you enable Smart Licensing, the Cisco Software License (CSL) and all licensing calls pass through the Smart Agent. For the ‘no’ case, if Smart Licensing is already registered, the Smart Agent performs the ”license smart deregister” operation that deactivates Smart Licensing. Reload the device to activate the CSL on the device.
Step 4
exit
Example:
Device(config)# exit
Step 5
write memory
Example:
Step 6
reload
Example:
Device# reload
(Optional) Restarts the device to enable the new feature set.
Note
Reload the device if you have not reloaded the device after configuring the Cisco One Suites.
Step 7
show license all
Example:
Device Registration
Procedure
Step 1
enable
Example:
Device> enable
Step 2
license smart register idtoken idtoken [force]
Example:
Device# license smart register idtoken 123
Registers the device with the back-end server. Token id can be obtained from your virtual a/c in the Smart Licensing server.
  • force : To forcefully register your device irrespective of either the device is registered or not.
Note The device supplies the token ID to the Cisco server, which sends back a “Device Certificate” that is valid for 365 days.
Step 3
Example:
Device# license smart deregister
Deregisters the device from the backend server.
Step 4
license smart renew [ID | auth]
Example:
Device# license smart renew ID
(Optional) Manually renews the ID certification or authorization.
Response Signature
Thank you for your support! The issue was resolved.
Kind regards.
Sorry for late post.
We are going to buy c1111-8p with CON-3SNT-C11118P smarnet
does we neet to purchase any additional license for sec-k9 ?
and what it default lic ? ipbase?
Hello @Nithin Eluvathingal to activate the license using smart license means the device must be reacheable to the internet or cisco web?
It depends on the setup, it can be direct which you Connect your device to CSSM(cloud) or you can have SSM(onprem) in which device connect to your on prem server. SSM need to  connect with CSSM for license syncing or on an Air gap network you need to sync it manually uploading files.
https://www.cisco.com/c/en_my/products/software/smart-accounts/software-licensing.html#~stickynav=4
https://www.cisco.com/c/en_my/products/software/smart-accounts/software-licensing.html?socialshare=video-t2
Response Signature
sSiDs
