08-02-2011 07:53 AM - edited 03-04-2019 01:09 PM
It's not very clear for me.
Do I need to buy a license if I want to use OSPF or BGP on WS-C3560V2-24TS-E ?
Best Regards,
SGT
08-02-2011 08:21 AM
It depends on what feature set is preinstalled. If you are running IP Services already then no. If you are running IP Base then yes, you need to purchase a license and upgrade the IOS to the IP Services feature set.
Jon
08-02-2011 11:44 AM
I went through this issue with my 3560 and 3750 installation - as of v12.2(55), the base license includes OSPF. If you need BGP, then yes, you need IP Services. If you don't have 12.2(55) or higher, OSPF will not work on IP Base.
08-03-2011 01:27 AM
Thank you for your answer.
@jlmickens: Do you know if on your 3560 and 3750, the hardware model is TS-S or TS-E?
@jlmickens: Did you buy an extra license for BGP?
-> I thought TS-E means with IP services license included.
I forget to say that I don't ordered this device yet.
I'm afraid of extra cost if I want to use BGP/OSPF on this device WS-C3560V2-24TS-E.
08-03-2011 01:29 AM
I didn't ordered this switch yet.
Do you know which feature set will be preinstalled if I ordered WS-C3560V2-24TS-E?
Best Regards,
SGT
08-03-2011 05:42 AM
My 3560 is a WS-C3560G-24TS-S. A TS-E will have the IP Services license. You will pay more for the switch as opposed to a TS-S which has the IP Base set on it.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/data_sheet_c78-530976.html
Look at Table 7 towards the bottom - it explains which service set comes on each model. One thing to note, the switch you purchase may not necessarily have the latest version on it.
I believe you will need to decide whether you need to run OSPFor BGP (or both). If you need BGP, get the TS-E. If you only need OSPF, get the TS-S and update it to at least 12.2(55). The cost difference between IP Base and IP Services is at least $1500 iirc. I only needed OSPF, thus I only purchased the TS-S.
08-03-2011 07:33 AM
I have made a quick test on WS-C3560G-48TS-S.
I was able to upgrade to the following IOS c3560-ipservicesk9-mz.122-50.SE3.bin and I was able to perform the following command:
conf t
router bgp 1
Best Regards,
