Highlighted
Beginner
Limit Bandwith on Router based on active IPs
we have a network with one Router C800 with IOS 15, where 2 Switches are connected. Every user connected to one switch has a public IP, so no NAT is used, but there are multiple Subnets, each has a single VLAN. The router is connected via sfp to the Internet.
Is it possible to configure the router, such that the bandwith which is available, is shared  equally to each active IP, such that for example if there is only 1 IP active, it gets all bandwith or if 10 IPs are active, every IP gets 1/10? I do want to share it on IP basis, not on VLAN basis, I found in another posting. In only care about download rates from the Internet, no upload bandwith sharing is needed.
If possible, can you provide a sample configuration?
The reason is, I want to prohibit that 1 user uses all bandwith so noone else can use the Internet anymore.
Many thanks in before.
Everyone's tags (1)
