Link Balancer?
aotholland
I do not know the correct topic, i am sorry for this
Is there a link balancer product available at cisco like Barracuda Link Balancer 430?
Regards.
5 Replies 5
siddiqirf
Cisco ACE product can do load balancing based on links as well. Baracuda call it a link balancer. its just a marking thing as far as im concerned.
sorry i meant 'marketing' thing...
I have found this product. Thanks Siddigirf.
Cisco ACE 4710 Application Control Engine.
Is there a stand alone product? But 4710 is a product family of 6500 switches and 7600 serie routers.
Rgds.
Hi guys,
Cisco's ACE products (now end of life) to my knowledge balancer servers like a Citrix Netscaler if you will.  A link balancer will do the same idea but on ISPs.  Check out what I mean here: http://www.elfiq.com/otherproducts.
You also get a lot more for your project with Elfiq, namely it has the fail-to-wire capability so it's not a point of failure, which is important because you're looking at business continuity if you don't deploy in H/A.
/JP
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
BTW, if you're using Cisco routers, OER/PfR feature might be an option.
