312
cisco_voxity
Beginner
LLQ policy and cisco 888EA
Hi everyone,
I have  a problem with llq policy and a cisco 888EA router. In my test lab, i have an interface vlan1 which connect lan. Second interface is a vlan 3 and simulate a wan connection.
From my linux laptop i send 20Mbit/s of udp trafic, and a phone (on other port in vlan1) try to make a call.
This call is absolutly unusable, voice cut, echo etc.
I have set a LLQ policy on Vlan 3 output but nothing ...
Any ideas ? What is wrong with my config ?
hostname r1
boot-start-marker
boot-end-marker
enable secret 5 $1$aMyD$y6X6MgJzOjzfJFFizYQU6.
aaa new-model
aaa session-id common
clock timezone FR 1 0
clock summer-time FR recurring last Sun Mar 2:00 last Sun Oct 3:00
ip cef
ip dhcp excluded-address 10.0.0.254
ip dhcp pool phone-dhcp
 network 10.0.0.0 255.255.255.0
 domain-name voxity.fr
 dns-server 192.168.16.80 8.8.8.8
 default-router 10.0.0.254
 lease 0 8
no ip domain lookup
no ipv6 cef
license udi pid C888EA-K9 sn FCZ1837C244
username admin privilege 15 password 7 07192E54471D00
controller SHDSL 0
 mode efm
 dsl-group 0 pairs  0
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 2
track 1 interface Vlan2 ip routing
track 2 interface Vlan3 ip routing
track 3 list boolean and
 object 1
 object 2
class-map match-all voice-signaling
 match access-group 103
class-map match-all voice-traffic
 match access-group 102
policy-map VOICE-POLICY
 class voice-traffic
  priority percent 80
 class voice-signaling
  bandwidth 200
 class class-default
  fair-queue
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 isdn termination multidrop
interface Ethernet0
 no ip address
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 switchport access vlan 3
 no ip address
 speed 10
interface FastEthernet3
 switchport access vlan 2
 no ip address
 speed 100
interface Vlan1
 ip address 10.0.0.254 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
interface Vlan2
 ip address 192.168.16.175 255.255.255.0
 ip nat outside
interface Vlan3
 bandwidth 10000
 ip address 172.16.3.1 255.255.255.0
 ip nat outside
 service-policy output VOICE-POLICY
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map adsl interface Vlan3 overload
ip nat inside source route-map sdsl interface Vlan2 overload
ip route 0.0.0.0 0.0.0.0 172.16.3.254
ip route 0.0.0.0 0.0.0.0 192.168.16.1 2
ip access-list standard nat1
 permit 10.0.0.0 0.0.0.255
access-list 100 permit ip host 10.0.0.2 any
access-list 102 permit udp any host 192.168.16.79
access-list 103 permit udp any any eq 5060
access-list 103 permit tcp any any eq 5060
route-map sdsl permit 10
 match ip address nat1
 match interface Vlan2
route-map adsl permit 10
 match interface Vlan3
event manager applet clearnat
 event track 3 state any
 action 1.0 cli command "enable"
 action 1.5 cli command "clear ip nat trans *"
 action 2.0 syslog priority notifications msg "Nat translation cleared!"
end
show policy-map interface vlan 3 output
 Vlan3
  Service-policy output: VOICE-POLICY
    queue stats for all priority classes:
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
    Class-map: voice-traffic (match-all)
      28492 packets, 6150256 bytes
      5 minute offered rate 52000 bps, drop rate 0000 bps
      Match: access-group 102
      Priority: 80% (8000 kbps), burst bytes 200000, b/w exceed drops: 0
    Class-map: voice-signaling (match-all)
      99 packets, 66993 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: access-group 103
      Queueing
      (pkts output/bytes output) 77/52806
      bandwidth 200 kbps
    Class-map: class-default (match-any)
      192300 packets, 278670064 bytes
      5 minute offered rate 1080000 bps, drop rate 0000 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops/flowdrops) 0/0/0/0
      (pkts output/bytes output) 3212/741752
      Fair-queue: per-flow queue limit 16 packets
Thanks for you help,
Regards.
4 REPLIES 4
Joseph W. Doherty
Hall of Fame Expert
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Does this model 800 have a "WAN" port?  If so, try your WAN connection on that.  If your simulated WAN offers less than FE bandwidth, shape for the available bandwidth.
Yes 800 have a wan port, but in my case, i dont have a SHDSL connection on my office, so i "simulate" wan connection on FE.
I have set speed to 10Mbits-FD on FastEthernet2 and i send for my laptop 20Mbit/s of udp trafic. 50% of this trafic has been drop but if i make a voice call during speed test, rtp trafic has been dropped to...
As you can see, i have set an access list 102 with a dest IP address. This adress is asterisk voice server. This trafic should be more prioritaire than "classic" udp trafic, and voice packets should not be dropped no ?
Regards.
Disclaimer
Posting
The possible problem is, your QoS is applied on the SVI not the physical port and so I believe the VLAN doesn't respond to its single VLAN ports as you would expect.  An indication of this is if you're sending faster than your egress bandwidth but not seeing any (?) drops in your policy (if true, the SVI doesn't "see" the congestion).  (Yea, and I know, you only have the one port in the VLAN, but the congestion still could be on the physical port, not SVI.)
The foregoing is why I suggested using the "WAN" port; often on 800s, it supports routed port QoS.  (And yes, understand on your model it's not an Ethernet port, so you're unable to easily test with it.)
So, again, you might try a shaper on the SVI (if supported) (also note, I believe most shapers don't account for L2 overhead, so you'll need to shape "slower").
Hum ok, thank for your answer, i think that SVI does not see congestion because drop's counter has not been increased even if paquets has been droped.
So packets will not be classifed if i use lan port as a second wan port.
Many thanks for you answer,
Regards.
