03-11-2015 06:35 PM - edited 03-05-2019 01:00 AM
Dear All
There are two locations, site A and site B. I am confused with it. Any one can help to understand it? The site A and B are connected with two paths. One is MPLS and another is VPN over internet. we want MPLS as primary path and L2L VPN as backup. Only when primary path is down, VPN can be used. How can we configure it ? Can you give me suggestion ? or a link. Thank you.
03-12-2015 02:39 AM
Hello yangfrank,
You can set this with a floating static using tracking with ip sla.
Your primary route will be via MPLS
ip route 0.0.0.0 0.0.0.0 x.x.x.x track 1 (via MPLS)
ip route 0.0.0.0 0.0.0.0 y.y.y.y 10 (via VPN)
ip sla 1
icmp-echo z.z.z.z source interface gix/x (MPLS interface)
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
here are examples:
http://networklessons.com/ip-routing/reliable-static-routing-with-ip-sla/
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/813-cisco-router-ipsla-basic.html
hope this helps
03-12-2015 07:07 PM
Good idea, Thank you Bilal !
03-12-2015 03:28 AM
Hello.
Could you share your configuration?
If you have more than 1 router per site, could you share network diagram?
