Load Balance on 3825
francescoturato
Hi All,
i have a c3825 ( that now is standard with 2 GigabitEthernet interface but i can install any module ) and i need to connect both my AS-links versus internet on it. So how can i do load balance between any interface to get best result from my double internet connection??
Thank for any answer
5 Replies 5
cadet alain
Cisco routers don't do load-balancing, they do load-sharing and the default is per src-dst IP pair.
You can verify which path traffic will take with the show ip cef exact-route command specifying the src and dst IPs.
Alain
Alain ty for your answer .. but if u can be more specific on configuration .. couse u are sure much more skilled then me in Cisco world.
for traffic to be load-shared you need equal cost(metric) routes installed for the same prefix(in your case the default route).
So just configure 2 static default routes pointing to the next-hop or dialer interface if you are doing PPPoE.
example:
ip route 0.0.0.0 0.0.0.0 dialer1
ip route 0.0.0.0 0.0.0.0 dialer 2
For NAT: here's an example with fe0/0 being LAN interface
int f0/0
ip add 192.168.1.254 255.255.255.0
ip nat inside
no shut
int dialer 1
ip nat outside
int dialer2
ip nat outside
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
route-map DIALER1
match ip address 101
match interface dialer1
route-map DIALER2
match interface dialer2
ip nat inside source route-map DIALER1 interface dialer1
ip nat inside source route-map DIALER2 interface dialer2
Alain
thnks so much Alain
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
If your IOS (with correct feature set) supports it, OER/PfR can load balance your egress.
