Load Balance using MLPPP
jeffbriones
hi guys,
my isp told me to use multilink ppp to load balance our connectivity to them. will these setup work ? i have 2 atm interfaces and bgp configuration. can you please give an examples on these.
thanks
jeff
AhsanMohiuddin
what encapsulation does your atm interfaces use? multilink ppp is useful only for ppp encap types. Maybe your ISP wants you to use Cisco proprieetary Bandwidth on Demand (BoD). Here is a sample.
int bri0
encap ppp
dialer map ip 10.1.1.1 name Aussie 8001234
dialer map ip 10.1.1.1 name Aussie 8005678
dialer load-threshold 1 either
this will dial your both B-channels to same destination using ISDB bri interface
Atm interfaces uses aal5snap encapsulation. Im checking these interface Multilink and virtual-template commamds here. No dialer map ...
