Load Balancer
pctech2009
Community Member
can cisco 1800 series router be used for load balancing router to connect 2 hub/switch without changing the given ip address by the ISP?
Giuseppe Larosa
Hello Sherwin,
using NAT you can implement a "poor man " load balancer
see
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
or better for you :
Avoiding Server Overload Using Load Balancing: Example
In the following example, the goal is to define a virtual address, connections to which are distributed among a set of real hosts. The pool defines the addresses of the real hosts. The access list defines the virtual address. If a translation does not already exist, TCP packets from serial interface 0 (the outside interface) whose destination matches the access list are translated to an address from the pool.
ip nat pool real-hosts 192.168.15.2 192.168.15.15 prefix-length 28 type rotary
ip nat inside destination list 2 pool real-hosts
interface serial 0
ip address 192.168.15.129 255.255.255.240
ip nat outside
interface ethernet 0
ip address 192.168.15.17 255.255.255.240
ip nat inside
access-list 2 permit 192.168.15.1
see
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_addr_consv_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1073492
Hope to help
Giuseppe
