load balancing between static and ebgp paths ?
thomastrupel
Is-it possible to insert a static and an eBGP path in the RIB for the same prefix on Cisco IOS XE ?
Even modifying static route metric to be equal to eBGP administrative distance (20), static path prevail over eBGP path.
Help would be greatly appreciated,
Thomas
Richard Burts
Thomas
If it is for the same prefix then it is not possible to insert both a static route for the prefix and an EBGP route for the same prefix into the RIB.
Rick
Rick
Richard Burts
Thomas
Rick
Rick
Thank you Richard
Thomas
You are welcome. I am glad that my response was helpful. Thank you for using the rating system to mark this question as answered. This will help other readers in the forum to identify discussions which have helpful information.
Rick
Rick
