load balancing two equal WAN links
dcarr3311
Hello
I have a single gig WAN link to our back up Data Center. The WAN routers peer with BGP. The WAN routers distribute route to a Layer 3 switch running EIGRP. I am getting a second gig WAN link from another provider for increased Bandwidth and redundancy. Now I would would like to use the EIGRP equal cost load balancing to distribute between both links. But the Traffic is encrypted and has the same source and destination IP always. IS using per-packet round robin my only choice or can anyone think of another way to do this?
5 Replies 5
Hello
you have a few options but just one thing if your having a second wan link installed then you have two paths with different next hop addresses via two ddifferent isps  wouldn’t you unless I am missing something fundermental with what your saying?
Kind Regards
Paul
Hi Paul
the links are are dark fiber so Layer 2
Hello
can you post a topology of your network ipresently and what is expected
Kind Regards
Paul
The second proposed link is show below.. I can add additional routers if needed. And remember the source and destination IP's and port don't change.
[cid:image001.png@01D44033.931F9FA0]
[cid:image001.png@01D44053.CF261630]
