124
Beginner
Load balancing Wireless and serial link
I have a router with 2 WAN connections, One 2 MB E1 terminated to serial link and another wireless link terminated to Ethernet. Is it possible to load balance between the two. If so how?
thanks in advance
Rajesh
2 REPLIES 2
Hall of Fame Guru
Re: Load balancing Wireless and serial link
Rajesh
Yes you should be able to do this. If the links are the same speed then a dynamic routing protocol could be used and as long as it saw both links to the same destination it would use both.
If the links are a different speed you could use 2 static routes one for each link. Bear in mind though that if one link is much faster than the other you may be better off using the slower link purely as a backup.
Jon
Beginner
Dear Jon,
Thanks a lot
rgds
rajesh
Content for Community-Ad
July's Community Spotlight Awards
