load balancing
ammadshah
i have cisco 1811 router and two ISP links (DSL 1Mb, 512Kbps). i want to load balance between these two, if one goes down load shifts to secondary link, any idea to do this
thanks,
spremkumar
Level 9
Level 9
You can try out redundancy on the links instead of load sharing...
Though they are from different ISP's and you do the necessary config for outgoing traffic you dont have any control on the return traffic.This could well result in performance degrade issues...
Better use one link as primary and the other one as secondary...
regds
This document has all the scenarios
http://www.cisco.com/warp/public/459/40.html
Hope this helps. Please rate if it does.
-Harish
