Load Balancing
nikuhappy2010
Hi, I am looking a solution of load balancing between two ISP links which is configured on Router. Please suggest... Thanks.
paolo bevilacqua
See:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Note, you need to configure 2 default static routes, the example in the document above doesn't do that.
Please rate post if it helps!
mounir.mohamed
Level 7
Level 7
Hi nikuhappy2010,
A lot of techniques available for load-balance, so if you would like to share your topology and requirements or even more clarification about your setup i will be grateful.
Best Regards,
Mounir Mohamed
joseph.derrick
Load balancing can be achieved in numerous ways. Please provide more details regarding your existing setup.
One is, if you have to links to a different upstream providers, you can use BGP to load balance traffic. This allows a fail-over which is useful in many cases.
k0rg
