Join Customer Connection to register!
203
rabeder
Beginner
load-intervall on policy-map on 7606 router
hi,
we have a 7606 router which has policy-maps instaled:
mplsgrzpe01#sh policy-map interface GigabitEthernet1/1/1.1702
Service-policy output: egress_queue_parent_2000
Counters last updated 00:00:05 ago
Class-map: class-default (match-any)
269116 packets, 232562338 bytes
30 second offered rate 1045000 bps, drop rate 0 bps
Match: any
Queueing
queue limit 2048 packets
(queue depth/total drops/no-buffer drops) 0/0/0
(pkts output/bytes output) 251106/216408176
shape (average) cir 1900000, bc 7600, be 7600
target shape rate 1900000
Queue-limit 2048
Service-policy : egress_queue
queue stats for all priority classes:
Queueing
queue limit 409 packets
(queue depth/total drops/no-buffer drops) 0/16901/0
(pkts output/bytes output) 51180/44184584
Class-map: system_intern (match-any)
2273 packets, 282846 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: dscp cs6 (48)
Match: mpls experimental topmost 6
Queueing
queue limit 102 packets
(pkts output/bytes output) 2270/282530
bandwidth 5% (95 kbps)
Class-map: voice (match-any)
68371 packets, 59641582 bytes
30 second offered rate 287000 bps, drop rate 103000 bps
Match: dscp ef (46)
Match: mpls experimental topmost 5
Priority: 20% (380 kbps), burst bytes 9500
Class-map: gold (match-any)
68420 packets, 59674152 bytes
30 second offered rate 287000 bps, drop rate 0 bps
Match: dscp af42 (36)
Match: mpls experimental topmost 4
Queueing
queue limit 512 packets
(pkts output/bytes output) 68147/59439118
bandwidth 25% (475 kbps)
Class-map: silber (match-any)
68423 packets, 59648166 bytes
Match: dscp af32 (28)
Match: mpls experimental topmost 3
Queueing
(pkts output/bytes output) 68174/59438380
bandwidth 20% (380 kbps)
61629 packets, 53315592 bytes
Match: any
Queueing
(pkts output/bytes output) 61335/53063564
mplsgrzpe01#
the problem is that if i make a "sh policy-map int gig1/1/1.1702" the time update time is very long, although load-interval is set to 30 seconds.
for example if there is traffic with 300kb/s in voice-queue, it takes a long time (till minutes that the "offered rate" is 300 kb/s).
if i stop forwarding traffic to the voice-queue, it also takes minutes, tille the "offered-rate" value goes down to zero bits per seconds.
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB2,
System image file is "bootdisk:c7600rsp72043-advipservicesk9-mz.122-33.SRB2.bin"
Last reload type: Normal Reload
the next problem is, that we have drops in our voice_queue althoug there is 380kb/s reserved in voice-queue and we do NOT exceed this value
thanks for any help
0 REPLIES 0
