Load share from 2 x 800 series adsl routers
does anyone have an example of how I can setup load sharing of two 887 VA Routers each with its own adsl line to enable me to double my bandwidth?
I was thinking about connecting them both to an 1800 series router and then a switch.
But really looking for ideas or maybe a solution if this exists already.
Thx
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Yes, you can do that, or if the switch is L3, you might just connect directly to it.  Further, if the 887s support GLBP, you might be able to connect them to a L2 switch, and load balance.
For optimal egress load balancing, you'll want to use PfR.  (Don't know if supported on 887s.
From another router, or a L3 switch, just route out (equally) to each of your 887s.
From a L2 switch, have your two 887s run GLBP in load sharing mode.  (For this to work well, you need a good distribution of egress from multiple hosts.)
