Load sharing between three links
Arun
I have three DS3 links connected between two routers. I want 50% of my traffic go through link1 ,30% go through link2 and remaining 20% traffic go through link.is there any way to acheive this.
Arun
cadet alain
with EIGRP you could achieve this with unequal cost load sharing but that is the only way I can think of right now.
Alain
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Besides Alain's suggestion of EIGRP, I believe OER or PfR (if supported on your platform) might do that, and it would do it dynamically.  You might also be able to do static load balancing with 10 static routes, 5 on link1, 3 on link2 and 2 on link3.  (NB: You'll need different next hop IPs for each static.)
