Load Sharing between Two Links
mannikoth
Hi all ,
I will be having internet from Two Servide Providers.and i would like to have Parelell useage of both links with NATing & DHCP.
which is the best option whether HSRP or Cisco Optimized Edge Routing.
spremkumar
Level 9
Level 9
You can very well think off on with GLBP which actually provides load balancing with built in redundancy without any additional configs when compared to HSRP where you need to have different group configs to have load balancing done between 2 different links connected on different equipments..
do refer this on how to go about on the same..
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a008042fb97.html
regds
