loading
arjun_4790
hello,
cisco 2821 has been loading relentlessly, not stopping and not getting to user execution mode
5 Replies 5
is that a first generation 2821 (meaning, how old is the device) ?
Can you get into ROMMON (power down/up the router and press Break on the terminal keyboard within 60 seconds of power up) ?
hello,
thanks for assisting it's been working ..have given 0x2142 in rommon mode and reset it but the data which has been saved has been lost, could I retrieve that data??
with data I assume you mean the configuration ? Check if it is saved in flash:
2821#dir flash:
What is the output of that command ?
hello,
yes I was talking about configuration, please find the attachment of that output.
unfortunately, no configuration file has been saved, so you have to start from scratch. Let us know if you need help with that...
