Loadsharing between Internet leased line and DSL
vicky.dhas
Hi All,
I have a dedicated internet link with /29 public IP from my ISP.I plan to take a DSL link from anoher ISP and and loadshare between the links.Both link will be terminated on my firewall.Can you share be some best practise to achieve this.
Vicky
Kelvin Willacey
Level 4
Level 4
If your firewall is an ASA then you are out of luck, if it is a router then you will need to use PBR.
PBR is not needed with routers:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
That can definitely work too but I figured that would not be the solution since Vicky said load sharing. I guess it's just a matter of interpretation.
