Local host not working because of NAT?
Tyler Woods
I'm sure this is a simple one but it is beyond me at the moment. I have a host on an inside interface that is going out NAT'd behind the outside interface of an ASA trying to gain access to host on that same outside interface via an ARIN address we have.
See the following in logs:
Deny IP spoof from (97.x.x.226) to 205.x.x.108 on interface outside
The 97.x.x.226 is the outside interface IP address and the 205.x.x.108 is the ARIN address with a static NAT to host on another inside network.
Using Packet Tracer gives me this:
Anti-spoofing is not enabled on any interfaces at the moment.
Any assistance in the right direction would be greatly appreciated. The inside host initiating communication needs to access other sites on the Internet as well so I don't want to mess that functionality up.
5 Replies 5
Oleg Volkov
Can You post configuration of this ASA?
Helping seriously ill children, all together. All information about this, is posted on my blog
ASA Version 8.2(3)
hostname GL
names
dns-guard
interface Ethernet0/0
 description GL-Networks
 nameif outside
 security-level 0
 ip address 97.x.x.226 255.255.255.248 standby 97.x.x.227
interface Ethernet0/1
 no nameif
 no security-level
 no ip address
interface Ethernet0/1.11
 vlan 11
 nameif KPinside
 security-level 50
 ip address 10.16.11.1 255.255.255.0 standby 10.16.11.4
interface Ethernet0/1.98
 vlan 98
 nameif vlan98
 security-level 50
 ip address 10.64.98.1 255.255.255.0 standby 10.64.98.4
interface Ethernet0/1.111
 vlan 111
 nameif KPdmz
 security-level 20
 ip address 172.26.11.1 255.255.255.0 standby 172.26.11.4
interface Ethernet0/1.192
 vlan 192
 nameif vlan192
 security-level 50
 ip address 192.168.1.1 255.255.255.0 standby 192.168.1.4
interface Ethernet0/2
 nameif vlan205
 security-level 50
 ip address 10.64.96.1 255.255.255.0 standby 10.64.96.4
interface Ethernet0/3
 description LAN/STATE Failover Interface
interface Management0/0
 shutdown
 no nameif
 no security-level
 no ip address
 management-only
boot system disk0:/asa823-k8.bin
ftp mode passive
clock timezone PST -8
dns domain-lookup vlan98
dns domain-lookup vlan192
dns domain-lookup vlan205
dns server-group DefaultDNS
 name-server 10.64.97.15
 name-server 10.64.97.14
 domain-name g.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network GL-ACTUAL
 network-object 10.64.96.0 255.255.255.0
 network-object 10.64.98.0 255.255.255.0
 network-object 10.64.97.0 255.255.255.0
 network-object 192.168.1.0 255.255.255.0
object-group network BVT-ACTUAL
 network-object 10.6.57.0 255.255.255.0
 network-object 10.6.48.0 255.255.255.0
 network-object 10.6.51.0 255.255.255.0
 network-object 172.29.15.0 255.255.255.0
 network-object 172.29.14.0 255.255.255.0
 network-object 10.6.245.0 255.255.255.0
 network-object 10.6.26.0 255.255.255.0
 network-object 10.6.252.0 255.255.255.0
 network-object 10.6.7.0 255.255.255.0
 network-object 172.29.10.0 255.255.255.0
 network-object 172.29.21.0 255.255.255.0
 network-object 172.29.6.0 255.255.255.0
 network-object 10.6.5.0 255.255.255.0
 network-object 10.6.6.0 255.255.255.0
 network-object 10.6.1.0 255.255.255.0
 network-object 10.6.16.0 255.255.255.0
 network-object 10.6.4.0 255.255.255.0
 network-object 10.6.31.0 255.255.255.0
 network-object 10.6.11.0 255.255.255.0
 network-object 10.6.21.0 255.255.255.0
 network-object 10.6.33.0 255.255.255.0
object-group network GLOFFICE-ACTUAL
 network-object 10.64.99.0 255.255.255.0
 network-object 192.168.199.0 255.255.255.0
object-group network DR-ACTUAL
 network-object 192.168.254.0 255.255.255.0
 network-object 10.6.248.0 255.255.255.0
 network-object 10.6.151.0 255.255.255.0
 network-object 172.29.215.0 255.255.255.0
 network-object 172.29.214.0 255.255.255.0
 network-object 172.29.206.0 255.255.255.0
 network-object 10.6.205.0 255.255.255.0
 network-object 10.6.250.0 255.255.255.0
object-group network KP-PROD
 network-object 10.16.11.0 255.255.255.0
object-group network Ext-KP
 network-object host 205.x.x.11
object-group service KPRDP
 description 10.16.11.202
 service-object tcp eq 3389
 service-object tcp-udp eq 445
 service-object tcp-udp range 1024 65535
 service-object tcp eq 135
 service-object tcp eq 5504
 service-object tcp eq 5722
 service-object tcp-udp eq 464
 service-object udp eq netbios-dgm
 service-object udp eq netbios-ns
 service-object tcp eq netbios-ssn
 service-object udp eq isakmp
object-group service KPAD
 description 10.16.11.203
 service-object tcp-udp eq 389
 service-object tcp eq ldaps
 service-object tcp eq 3268
 service-object tcp eq 3269
 service-object tcp-udp eq 88
 service-object tcp-udp eq domain
 service-object tcp eq 42
 service-object tcp eq smtp
 service-object udp eq ntp
 service-object tcp-udp eq 1812
object-group icmp-type ping
 icmp-object echo
 icmp-object echo-reply
object-group network PrivateIPs
 network-object 10.0.0.0 255.0.0.0
 network-object 172.16.0.0 255.240.0.0
 network-object 192.168.0.0 255.255.0.0
object-group network KPRDPaccess
 This group contains multiple "network-object host" for external sites I am permitting 10.16.11.202 access to.
object-group service KPRDPservicesAccess
 service-object tcp eq www
 service-object tcp eq https
object-group network obj_ns1.g.com
 network-object 205.x.x.100 255.255.255.255
object-group network obj_ns2.g.com
 network-object 205.x.x.101 255.255.255.255
object-group network obj_ws.g.com
 network-object 205.x.x.103 255.255.255.255
object-group network obj_images.g.com
 network-object 205.x.x.105 255.255.255.255
object-group network obj_allw.com
 network-object 205.x.x.106 255.255.255.255
object-group network obj_g.com-haproxy
 network-object 205.x.x.107 255.255.255.255
object-group network obj_int.g.com
 network-object 205.x.x.108 255.255.255.255
object-group network obj_post.g.com
 network-object 205.x.x.109 255.255.255.255
object-group network obj_get.g.com
 network-object 205.x.x.110 255.255.255.255
object-group network obj_mail.g.com
 network-object 205.x.x.111 255.255.255.255
object-group network obj_mobile.g.com
 network-object 205.x.x.112 255.255.255.255
object-group network obj_api-test.g.com
 network-object 205.x.x.115 255.255.255.255
object-group network obj_preview.g.com
 network-object 205.x.x.117 255.255.255.255
object-group network obj_ci.g.com
 network-object 205.x.x.118 255.255.255.255
object-group network obj_demo.g.com
 network-object 205.x.x.125 255.255.255.255
object-group network obj_GLport20
 group-object obj_get.g.com
 group-object obj_int.g.com
 group-object obj_post.g.com
object-group network obj_GLport21
object-group network obj_GLport22
 group-object obj_preview.g.com
object-group network obj_GLport25
 group-object obj_mail.g.com
 group-object obj_ns1.g.com
object-group network obj_GLport53
 group-object obj_ns2.g.com
object-group network obj_GLport80
 group-object obj_allw.com
 group-object obj_api-test.g.com
 group-object obj_demo.g.com
 group-object obj_g.com-haproxy
 group-object obj_images.g.com
 group-object obj_mob.g.com
 group-object obj_prev.g.com
 group-object obj_ws.g.com
object-group network obj_GLport443
 group-object obj_ci.g.com
object-group network obj_GLport2121
object-group network obj_GLport8080
access-list outside-access extended permit icmp any 205.x.x.0 255.255.255.0 object-group ping
access-list outside-access remark -- Begin gl
access-list outside-access extended permit tcp any object-group obj_GLport20 eq ftp-data
access-list outside-access extended permit tcp any object-group obj_GLport21 eq ftp
access-list outside-access extended permit tcp any object-group obj_GLport22 eq ssh
access-list outside-access extended permit tcp any object-group obj_GLport25 eq smtp
access-list outside-access extended permit tcp any object-group obj_GLport53 eq domain
access-list outside-access extended permit udp any object-group obj_GLport53 eq domain
access-list outside-access extended permit tcp any object-group obj_GLport80 eq www
access-list outside-access extended permit tcp any object-group obj_GLport443 eq https
access-list outside-access extended permit tcp any object-group obj_GLport2121 eq 2121
access-list outside-access extended permit tcp any object-group obj_GLport8080 eq 8080
access-list outside-access remark -- Begin KP
access-list outside-access extended permit tcp any host 205.x.x.11 eq https
access-list outside-access extended permit tcp any host 205.x.x.12 eq ftp
access-list outside-access extended permit tcp any host 205.x.x.12 eq ftp-data
access-list glprod-bvt extended permit ip object-group GL-ACTUAL object-group BVT-ACTUAL
access-list glprod-bvt extended permit ip host 97.x.x.226 host 10.6.245.6
access-list glprod-bvt extended permit ip object-group KP-PROD object-group BVT-ACTUAL
access-list glprod-bvt extended permit ip object-group KP-PROD 10.50.2.0 255.255.255.0
access-list glprod-bvt extended permit ip host 172.26.11.10 object-group BVT-ACTUAL
access-list nonat-intervlan extended permit ip 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list nonat-intervlan extended permit ip 10.64.96.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list nonat-intervlan extended permit ip 10.64.97.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list nonat-intervlan extended permit ip 10.64.98.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list nonat-intervlan extended permit ip object-group GL-ACTUAL object-group GL-ACTUAL
access-list nonat-intervlan extended permit ip 10.64.98.0 255.255.255.0 object-group BVT-ACTUAL
access-list nonat-intervlan extended permit ip 10.64.97.0 255.255.255.0 object-group BVT-ACTUAL
access-list nonat-intervlan extended permit ip 10.64.96.0 255.255.255.0 object-group BVT-ACTUAL
access-list nonat-intervlan extended permit ip object-group GL-ACTUAL object-group BVT-ACTUAL
access-list nonat-intervlan extended permit ip object-group GL-ACTUAL object-group GLOFFICE-ACTUAL
access-list nonat-intervlan extended permit ip object-group GL-ACTUAL object-group DR-ACTUAL
access-list nonat-intervlan extended permit ip object-group KP-PROD object-group BVT-ACTUAL
access-list nonat-intervlan extended permit ip object-group KP-PROD 10.50.2.0 255.255.255.0
access-list nonat-intervlan extended permit ip 172.26.11.0 255.255.255.0 object-group KP-PROD
access-list nonat-intervlan extended permit ip object-group KP-PROD 172.26.11.0 255.255.255.0
access-list nonat-intervlan extended permit ip host 172.26.11.10 object-group BVT-ACTUAL
access-list icmp extended permit icmp any any
access-list vlan98-outbound extended permit ip 10.64.98.0 255.255.255.0 any
access-list vlan98-outbound extended permit ip 10.64.98.0 255.255.255.0 object-group BVT-ACTUAL
access-list vlan205-outbound extended permit ip 10.64.96.0 255.255.255.0 any
access-list vlan205-outbound extended permit ip 10.64.96.0 255.255.255.0 object-group BVT-ACTUAL
access-list glprod-gloffice extended permit ip object-group GL-ACTUAL object-group GLOFFICE-ACTUAL
access-list glprodvpn_splitTunnelAcl standard permit 192.168.1.0 255.255.255.0
access-list glprodvpn_splitTunnelAcl standard permit 10.64.96.0 255.255.255.0
access-list glprodvpn_splitTunnelAcl standard permit 10.64.98.0 255.255.255.0
access-list glprodvpn_splitTunnelAcl standard permit 10.64.97.0 255.255.255.0
access-list glprodvpn_splitTunnelAcl standard permit 192.168.199.0 255.255.255.0
access-list outside_cryptomap extended permit ip object-group GL-ACTUAL object-group GLOFFICE-ACTUAL
access-list policy1 extended permit tcp host 10.64.96.5 any eq smtp
access-list policy2 extended permit tcp host 10.64.96.5 any
access-list policy2 extended permit udp host 10.64.96.5 any
access-list gl-dr extended permit ip object-group GL-ACTUAL object-group DR-ACTUAL
access-list KPdmzAccess1 extended permit object-group KPRDP host 172.26.11.10 host 10.16.11.202
access-list KPdmzAccess1 extended permit icmp host 172.26.11.10 host 10.16.11.202 object-group ping
access-list KPdmzAccess1 extended permit object-group KPAD host 172.26.11.10 host 10.16.11.203
access-list KPdmzAccess1 extended permit icmp host 172.26.11.10 host 10.16.11.203 object-group ping
access-list KPdmzAccess1 extended deny ip 172.26.11.0 255.255.255.0 object-group PrivateIPs
access-list KPdmzAccess1 extended permit ip 172.26.11.0 255.255.255.0 any
access-list KPinsideAccess1 extended permit ip host 10.16.11.202 object-group KPRDPaccess
access-list KPinsideAccess1 extended deny object-group KPRDPservicesAccess host 10.16.11.202 any
access-list KPinsideAccess1 extended permit ip 10.16.11.0 255.255.255.0 10.50.2.0 255.255.255.0
access-list KPinsideAccess1 extended deny ip 10.16.11.0 255.255.255.0 object-group PrivateIPs
access-list KPinsideAccess1 extended permit ip 10.16.11.0 255.255.255.0 any
access-list capin extended permit ip host 10.16.11.77 host 205.x.x.108
access-list capin extended permit ip host 205.x.x.108 host 10.16.11.77
access-list capout extended permit ip host 10.16.11.77 host 205.x.x.108
access-list capout extended permit ip host 205.x.x.108 host 10.16.11.77
access-list capin1 extended permit ip host 10.16.11.77 host 205.x.x.108
access-list capin1 extended permit ip host 205.x.x.108 host 10.16.11.77
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu KPinside 1500
mtu vlan98 1500
mtu KPdmz 1500
mtu vlan192 1500
mtu vlan205 1500
ip local pool glprodvpn 192.168.200.1-192.168.200.25 mask 255.255.255.0
failover
failover lan unit primary
failover lan interface FC Ethernet0/3
failover key gl123
failover link FC Ethernet0/3
failover interface ip FC 10.10.10.10 255.255.255.0 standby 10.10.10.20
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
global (outside) 5 205.x.x.111
nat (KPinside) 0 access-list nonat-intervlan
nat (KPinside) 1 0.0.0.0 0.0.0.0
nat (vlan98) 0 access-list nonat-intervlan
nat (vlan98) 1 0.0.0.0 0.0.0.0
nat (KPdmz) 0 access-list nonat-intervlan
nat (KPdmz) 1 0.0.0.0 0.0.0.0
nat (vlan192) 0 access-list nonat-intervlan
nat (vlan192) 1 0.0.0.0 0.0.0.0
nat (vlan205) 0 access-list nonat-intervlan
nat (vlan205) 5 access-list policy1
nat (vlan205) 1 access-list policy2
nat (vlan205) 1 0.0.0.0 0.0.0.0
static (KPdmz,outside) 205.x.x.11 172.26.11.10 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.118 10.64.96.118 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.100 10.64.96.100 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.101 10.64.96.101 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.103 10.64.96.103 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.105 10.64.96.105 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.106 10.64.96.106 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.107 10.64.96.107 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.108 10.64.96.108 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.109 10.64.96.109 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.110 10.64.96.110 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.112 10.64.96.112 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.115 10.64.96.115 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.117 10.64.96.117 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.125 10.64.96.125 netmask 255.255.255.255
static (vlan205,outside) 205.x.x.111 10.64.96.111 netmask 255.255.255.255
static (KPdmz,outside) 205.x.x.12 172.26.11.88 netmask 255.255.255.255
access-group outside-access in interface outside
access-group KPinsideAccess1 in interface KPinside
access-group KPdmzAccess1 in interface KPdmz
route outside 0.0.0.0 0.0.0.0 97.x.x.225 1
route vlan205 10.64.97.0 255.255.255.0 10.64.96.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 vlan98
snmp-server host vlan98 10.6.4.18 community 2bon2b
snmp-server host vlan205 10.64.97.162 community glpublic version 2c
snmp-server location Beaverton, OR
snmp-server contact Ben Maynard <bmaynard@g.com>
snmp-server community glpublic
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
snmp-server enable traps ipsec start stop
snmp-server enable traps entity config-change fru-insert fru-remove
snmp-server enable traps remote-access session-threshold-exceeded
sysopt connection tcpmss 1300
sysopt connection preserve-vpn-flows
service resetoutside
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set esp-aes-sha esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_dynmap 10 match address glprod-bvt
crypto map outside_dynmap 10 set peer 208.x.x.14
crypto map outside_dynmap 10 set transform-set ESP-3DES-MD5
crypto map outside_dynmap 10 set security-association lifetime seconds 28800
crypto map outside_dynmap 10 set security-association lifetime kilobytes 4608000
crypto map outside_dynmap 20 match address glprod-gloffice
crypto map outside_dynmap 20 set peer 50.x.x.141
crypto map outside_dynmap 20 set transform-set ESP-3DES-MD5
crypto map outside_dynmap 20 set security-association lifetime seconds 28800
crypto map outside_dynmap 20 set security-association lifetime kilobytes 4608000
crypto map outside_dynmap 25 match address gl-dr
crypto map outside_dynmap 25 set peer 97.x.x.210
crypto map outside_dynmap 25 set transform-set ESP-3DES-MD5
crypto map outside_dynmap 25 set security-association lifetime seconds 2147483640
crypto map outside_dynmap 25 set security-association lifetime kilobytes 2147483646
crypto map outside_dynmap 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_dynmap interface outside
crypto isakmp identity hostname
crypto isakmp enable outside
crypto isakmp policy 4
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 86400
crypto isakmp policy 10
 encryption 3des
 hash sha
 group 2
 lifetime 86400
crypto isakmp policy 11
 encryption aes
 hash sha
 group 2
 lifetime 86400
crypto isakmp policy 13
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
crypto isakmp nat-traversal 21
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 vlan98
ssh timeout 30
console timeout 0
management-access vlan98
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 enable outside
 svc enable
 tunnel-group-list enable
group-policy DfltGrpPolicy attributes
 dns-server value 10.64.97.15 10.64.97.14
 vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
 default-domain value g.com
 webvpn
  hidden-shares visible
group-policy glprodvpn internal
group-policy glprodvpn attributes
 vpn-tunnel-protocol IPSec svc
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value glprodvpn_splitTunnelAcl
 split-dns value g.com
group-policy GLPRODVPN internal
group-policy GLPRODVPN attributes
 webvpn
  svc keep-installer installed
  svc ask none default svc
tunnel-group 208.x.x.14 type ipsec-l2l
tunnel-group 208.x.x.14 ipsec-attributes
 pre-shared-key fbs123
tunnel-group 50.x.x.141 type ipsec-l2l
tunnel-group 50.x.x.141 ipsec-attributes
 pre-shared-key gl123
tunnel-group GLPRODVPN type remote-access
tunnel-group GLPRODVPN general-attributes
 address-pool glprodvpn
 default-group-policy GLPRODVPN
tunnel-group GLPRODVPN webvpn-attributes
 group-alias GLPRODVPN enable
tunnel-group glprodvpn type remote-access
tunnel-group glprodvpn general-attributes
 default-group-policy glprodvpn
tunnel-group glprodvpn ipsec-attributes
 pre-shared-key gl123!
tunnel-group 97.x.x.210 type ipsec-l2l
tunnel-group 97.x.x.210 ipsec-attributes
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect ip-options
  inspect ftp
  inspect icmp
service-policy global_policy global
prompt hostname context
Hello!
Can You do next:
packet-tracer icmp 10.16.11.10 1 1 8.8.8.8 detailed
And post the tesult
That is blocked by design. Only 10.16.11.202 is permitted to access specific IP addresses.
Called Cisco support and they resolved the issue.
Thank you for the assist Oleg.
