local interface not pinging
hendrikus1982
We have a Cisco ASR 1002 router.
While we have configured it the local interface is not pinging and nor is the remote IP address pingable.
What could be the issue ?
Nagendra Kumar Nainar
Do you have ESP module installed?. By having RP alone, the control plane will work, but any data plane functionality including local ping will not work.
Ca you check "show platform" to see if you have ESP installed?.
Nagendra
abcosting.com#show platform
Chassis type: ASR1002
Slot      Type                State                 Insert time (ago)
0         ASR1002-SIP10       ok                    04:55:14
 0/0      4XGE-BUILT-IN       ok                    04:52:57
R0        ASR1002-RP1         ok, active            04:55:14
P0        ASR1002-PWR-AC      ok                    04:54:24
P1        ASR1002-PWR-AC      ps, fail              04:54:24
Slot      CPLD Version        Firmware Version
0         07120202            15.3(3r)S
R0        08011017            15.3(3r)S
abchosting.com#
Per my understanding, Except fixed RU, all other ASR1k requires ESP. In your case, ESP is missing and so you cant ping you local address. Please see below for the datasheet,
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/data_sheet_c78-450070.html
You may need ESP to be included in this chassis inorder to have the dataplane functionality.
-Nagendra
Can you let us know where we buy ESP module?
Dont these all come with Cisco router ?
