Local preference bgp
prashantrecon
For 124 network i have given the local prefernce value as 300 but when i excuted the command value is not displaying ?
But 500 value is displaying .
route-map AIR, permit, sequence 10
  Match clauses:
    ip address prefix-lists: DEFAULT
  Set clauses:
    local-preference 300
Router-RSA#show ip bgp
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*  0.0.0.0          124.x.x.x            0             0 9XXX i
*>                  202.x.x.x          0    500      0 9XXX i
11 Replies 11
cadet alain
could you post output of sh ip prefix
Regards.
Alain
milan.kulik
Level 10
Level 10
I understand you are talking about the default route, not 124 network?
Are you sure the  prefix-lists DEFAULT is matching it?
And the route-map AIR is applied correctly?
If yes, have you tried
clear ip bgp * soft
on your router?
HTH,
Milan
ip prefix-list DEFAULT: 1 entries
   seq 5 permit 0.0.0.0/0
Do post your config excluding sensitive info for us to conclude
Rustom Billimoria
CCIE R&S# 24798
Sent from my BlackBerry® smartphone from Tata Indicom
I have even excuted the command clear ip bgp  still local prefernce is not displaying for 300.
Router-RSA#show route-map
route-map DEFAULT-SCY-SIF, permit, sequence 10
  Match clauses:
  Set clauses:
    local-preference 400
  Policy routing matches: 0 packets, 0 bytes
route-map DEFAULT-PRY-SIF, permit, sequence 10
  Match clauses:
  Set clauses:
    local-preference 500
route-map AIR-IN, permit, sequence 10
  Match clauses:
  Set clauses:
route-map AIR-OUT, permit, sequence 10
  Match clauses:
    ip address prefix-lists: AIR-OUT
  Set clauses:
route-map SIF-OUT, permit, sequence 10
  Match clauses:
    ip address prefix-lists: SIF-OUT
  Set clauses:
ip prefix-list AIR-OUT seq 5 permit 202.x.x.x/24
ip prefix-list DEFAULT seq 5 permit 0.0.0.0/0
ip prefix-list SIF-OUT seq 5 permit 202.x.x.x/24
it seems route-map DEFAULT-PRY-SIF is applied on the default route prefix received, not route-map AIR-IN.
Can you paste the config part where you are applying the route maps?
HTH,
Milan
yA route-map DEFAULT-PRY-SIF is applied on the default route prefix BUT WHEN ever SIF goes down .route-map AIR-IN
will be used .so when i excute show ip bgp when SIF goes down  local prefernce value for AIR is not displayed.
I believe the  route-map AIR-IN might not be applied for some reason.
Otherwise you should see LP 300 in ypur original output.
HTH,
Milan
It is applied when i shutdown interface to which SIF is applied than traffic is going through AIR_IN routemap
Hi Milan,
I reconfigured the bgp and clear ip bgp now it is working fine.
Thank Milan fot u help
Hi Prashant,
Do you have any other route-map entry with lower seq number which already matches the default route?
Did you apply the route map to the other neigbor (124.x.x.x) to in direction?
Did you try clear ip bgp with this neigbor?
Hope that helps,
Vasilis
