Logging Not Displayed
Hello Community,
I've set up my GNS3 router to log to console and terminal monitor at debug level, see below. However, when I can't see any logs. Can someone shed some light on the reason why?
Cheers
Carlton
R4#show logg
Syslog logging: enabled (11 messages dropped, 0 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 67 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: disabled, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
No active filter modules.
    Trap logging: level informational, 82 message lines logged
        Logging to 192.168.1.1(global) (udp port 514, audit disabled,  link up), 82 message lines logged, xml disabled,
               filtering disabled
R4#
stephen.stack
Level 4
Level 4
Add the logging buffered command. Example below
logging buffered 30000 informational
http://www.rConfig.com
A free, open source network device configuration management tool, customizable to your needs!
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
stephen.stack
Level 4
Level 4
Stephen
Carlton
