Looking for the right L3 switch
coletemple
I am looking for a L3 switch to use in our distribution layer with these capabilities:
-wccp v2 support (for our web cache)
-possibility to put a rate limit on each port of the switch
These two aspects are important among the others i already have.
Also I would like to be able to use fiber optic on the switchs ports(adapter or stand alone) in a nearer future to connect those ports to some other remote locations in my network.
answers will be much appreciated.
7 Replies 7
paolo bevilacqua
How much can you spend ?
as much as necessary.by the way, do you have any info about good websites where to find the products?
You can contact me to the address present in my profile for a lead to reputable resellers, new and used.
Giuseppe Larosa
Hello Paul,
a Cisco 3560 can be a solution it supports WCCPv2 and QoS / rate limiting.
For the fiber optics it should have two SFP slots
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_46_se/configuration/guide/swwccp.html
Hope to help
Giuseppe
Leo Laohoo
Have you visted the Cisco Product Advisor Tool? It's a very good interactive tool which will help you narrow down your choice to a few candidates.
http://www.ciscowebtools.com/ProductAdvisor/
When you are done, contact Paolo ahd he'll help you with alot of the nitty-gritty setup and configurations.
Hope this helps!
Paolo: Please don't forget me when you are organizing your Christmas list. he he he ...
Many thanks for your answer.really helpful.
Thanks for the link on cisco website about products. I am still trying to choose the right L3 switch (if possible, a generation below 4500 series) as I want also to implement some security features like TCP Intercept. Also, what does RP rate limiters stands for in the cisco product advisor web page? I want to be able to limit the rate on every port of the switch...
thanks
