Loopback0 issues
dizay8601
I'm trying to ping L0 on Core1 but it's not working! I tried everything but I don't understand the reason why
VPC6 and 5 are able to ping everything in this network except L0 on Core1
5 Replies 5
 Your access switch is doing layer 3, right? Are you using Dynamic protocol?  Which one?
show ip route on the Access switch does it show the L0 ip address?
Georg Pauwen
if possible, post the full running configs (sh run) of all three switches, as well as of the router...
SinghRaminder
any redistribution happening with Dynamic protocols if you are running them? Any Route-map preventing it?
Raminder
PS: If this answered your question, please don't forget to rate and select as validated answer
can I see output
trace route Lo core 1
Hello
Not enough information however It sounds like the loopback address(s) are not being advertised so the vpcs hosts are able to reach them.
Kind Regards
Paul
