10-14-2020 08:00 AM
Hi Everyone,
I have a Cisco router 2911 at my branch office, the problem is as follow:
when I do "ip nat outside" on g0/0 I lose the connectivity between the branches but the branch office successfully gains internet access from HQ
but if I do "no ip nat outside" on g0/0, I gain connectivity between branches but the branche loses internet connectivity.
How do I resolve it?
ip dhcp relay information option
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.11.253
ip dhcp excluded-address 192.168.11.252
ip dhcp excluded-address 192.168.8.1 192.168.8.50
ip dhcp pool CAIR-POOL
network 192.168.8.0 255.255.255.0
default-router 192.168.8.3
dns-server 10.10.1.4
domain-name repro.local
no ip domain lookup
ip name-server 8.8.8.8
no ipv6 cef
license udi pid CISCO2911/K9 sn FGL171911RN
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Internet
ip address 192.168.124.6 255.255.255.252
ip helper-address 192.168.124.6
ip directed-broadcast
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip dhcp relay information option-insert
ip address 192.168.8.3 255.255.255.0
ip helper-address 192.168.8.3
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip forward-protocol udp talk
no ip http server
no ip http secure-server
ip nat inside source list 111 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.124.5
ip route 192.168.8.0 255.255.255.0 192.168.8.1
ip route 192.168.124.0 255.255.255.252 192.168.124.5
ip route 192.168.124.0 255.255.255.252 192.168.124.2 254
ip route 192.168.124.4 255.255.255.252 192.168.124.5
access-list 111 permit ip 192.168.8.0 0.0.0.255 any
Solved! Go to Solution.
10-14-2020 08:24 AM
You don't say what your branch subnets are but try -
access-list 111 deny ip 192.168.8.0 0.0.0.255 <branch subnet1> <wildcard mask>
access-list 111 deny ip 192.168.8.0 0.0.0.255 <branch subnet2> <wildcard mask>
etc. for each branch subnet
Jon
10-14-2020 08:31 AM
Hello @Jonathan Nali ,
as explained by Jon Marshall your extended ACL 111 used for NAT must first deny communication with branch subnets and then have a final permit .
In this way the router will understand that it should NAT only when going to the Internet as desired.
The same reasoning would apply if the branch subnets are reached via a VPN for example.
Hope to help
Giuseppe
10-15-2020 03:03 AM
see the answer I have just provided to your ACL
You need to list the subnets of all branch ofices or at least find an aggregate like 192.168.0.0 0.0.255.255 to describe all of them
>> the problem is, I don't know what to deny. Can I deny they same network I am trying to permit?
in the NAT ACL the deny just means do not NAT traffic from local LAN to this destination it does not filter traffic like an ACL applied to an interface.
So yes you should deny all the networks that you want to reach without using NAT.
Hope to help
Giuseppe
10-14-2020 08:24 AM
Jon
10-14-2020 08:31 AM
Hope to help
Giuseppe
10-14-2020 10:27 AM - edited 10-14-2020 10:36 AM
Hi @Giuseppe Larosa and @Jon Marshall ,
I have read your replies but do not understand.
Should I leave my g0/0 interface on "ip nat outside"?
Also, what should I deny??
@Jon Marshall , To answer your question, my LAN only has one subnet which is /24, so do I deny only that one line??
10-14-2020 02:25 PM - edited 10-14-2020 02:31 PM
Yes leave the "ip nat outside".
Look at the example I have given ie. you need to add deny lines for the remote branch subnets whatever they are and then you need the permit at the end for your LAN to get to the internet as described by Giuseppe.
I am not sure how to explain it any clearer.
Jon
10-15-2020 01:14 AM
Hi Jon,
This is what I have done according to your advice. Again, maybe I did not understand what you were saying but it didn't work
#sh access-lists
Extended IP access list 110
10 deny ip 192.168.8.0 0.0.0.255 any (597 matches) (so you said I should first deny LAN access)
20 permit ip 192.168.8.0 0.0.0.255 any (Then I should permit it)
30 permit ip any any (201 matches)
Am I on track?
10-15-2020 02:55 AM - edited 10-15-2020 02:56 AM
unfortunately your extended ACL is wrong as the first line prevents NAT to happen for whatever destination.
#sh access-lists
First list the IP subnets of the branch offices that you need to reach WITHOUT NAT
example 192.168.12.0/24
The logic for using an extended ACL with NAT is the following:
first you deny the traffic coming from internal LAN and destined to internal destinations that do not need NAT
Later you permit traffic coming from your local internal LAN to any = Internet and this means it will be NATTed
access-list 115 remark NAT example
access-list 115 deny ip 192.168.8.0 0.0.0.255 192.168.12.0 0.0.0.255
access-list 115 permit ip 192.168.8.0 0.0.0.255 any
the ip nat outside has to remain on your Internet facing interface. It is the ACL that has to provide the intelligence to perform a selective NAT.
Hope to help
Giuseppe
10-15-2020 02:47 AM
Hi @Giuseppe Larosa ,
after reading your reply 100 times and rewatching ACL tutorials, I now understand what you are saying here:
Nali
10-15-2020 02:55 AM
what are the IP address ranges of your branches (e.g. 192.168.4.0/24) ?
10-15-2020 03:43 AM
Hi @Georg Pauwen ,
My branch office is 192.168.8.0/24 and to reach my HQ packets have to go through 192.168.124.0/32 to reach our HQ on 10.10.1.0/24
I hope this makes sense.
10-15-2020 03:03 AM
Hope to help
Giuseppe
10-15-2020 06:38 AM
One last question. On the same network I can now ping HQ from branch but I cannot ping from HQ to branch. So, do I put access-lists on the LAN side as well? I have tried this on the g0/1 (LAN) interface but not success.
From HQ(10.10.1.0/24) I can ping only upto the LAN interface (192.168.8.3)
How do I fix this?
Nali
10-15-2020 03:40 AM
Ok, I finally understood and got it right, thank you.
Add a deny statement to the other network and then the permit so that it only does NAT translations when going to the internet.
Thank you again @Jon Marshall and @Giuseppe Larosa
Nali
