10-01-2024 08:38 AM
hi,
i would like to express my issue and if you are able to advice me . i have a company router IR1101 with internet connection provided with private ipv4 address in the WAN interface. my company uses DMVPN in order to connect to company infrastructure. The issue is tha the connection of DMVPN is lost every 4 hours for 20-30 minutes. I checked the logs and i saw that there is authentication failure in the exchange message of the ikev2 . it is sometrhing that i cannot to explain since the site and router worked prefectly before this issue appeared.
Do you have any suggestions?
10-01-2024 08:49 AM
Run ip sla between spoke and hub make tunnel always UP.
It can ikev2 sa issue
MHM
10-01-2024 11:27 AM
what kind of logs can you post the logs here to look ?
is this Logs from head end or branch router, can you post both the logs ?
is this only 1 Router losing connection every 4 hours ? or all other branch routers ?
what is the head end router, what IOS code running both the sides ?
Guide lines how to troubleshoot :
10-01-2024 01:20 PM
10-01-2024 02:41 PM - edited 10-01-2024 02:44 PM
Hello @georgesofroniadis ,
at some point in the debug we see may requests no one of them get an answer
so at some point we see:
>> Oct 1 2024 13:33:40.872 UTC: IKEv2:(SESSION ID = 2,SA ID = 9):Sending Packet [To 193.x.y.207:4500/From 10.0.0.10:4500/VRF i0:f0]
Initiator SPI : C61FA05DBCD4E8BD - Responder SPI : 574998F98E3084B6 Message id: 1
IKEv2 IKE_AUTH Exchange REQUEST
Payload contents:
there are many attempts later we see a line that it is important :
Oct 1 2024 13:33:12.065 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Attrib type: split-dns, length: 0
Oct 1 2024 13:33:12.065 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Attrib type: banner, length: 0
--More-- Oct 1 2024 13:33:12.065 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Attrib type: config-url, length: 0
Oct 1 2024 13:33:12.065 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Attrib type: backup-gateway, length: 0
Oct 1 2024 13:33:12.065 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Attrib type: def-domain, length: 0
Oct 1 2024 13:33:12.065 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Have config mode data to send
Oct 1 2024 13:33:12.066 UTC: IKEv2:(SESSION ID = 1,SA ID = 8):Check for EAP exchange
SKF
finally:
Oct 1 2024 13:33:44.047 UTC: IKEv2-ERROR:(SESSION ID = 1,SA ID = 1):: Maximum number of retransmissions reached
Oct 1 2024 13:33:44.047 UTC: IKEv2:(SESSION ID = 1,SA ID = 1):Auth exchange failed
Oct 1 2024 13:33:44.047 UTC: IKEv2-ERROR:(SESSION ID = 1,SA ID = 1):: Auth exchange failed
Oct 1 2024 13:33:44.048 UTC: IKEv2:(SESSION ID = 1,SA ID = 1):Abort exchange
Oct 1 2024 13:33:44.051 UTC: IKEv2:(SESSION ID = 1,SA ID = 1):Deleting SA
Oct 1 2024 13:33:44.051 UTC: IKEv2:(SA ID = 1):[IKEv2 -> PKI] Close PKI Session
Oct 1 2024 13:33:44.052 UTC: IKEv2:(SA ID = 1):[PKI -> IKEv2] Closing of PKI Session PASSED
Oct 1 2024 13:33:46.616 UTC: IKEv2:(SESSION ID = 2,SA ID = 9):Retransmitting packet
note : if one side thinks the other part is a backup gateway and the primary is up it will stop to negotiate with your device.
at least I see this on Cisco Firepower 1140 with release 7.2.5.1 no IKEv2 exchange with backup peer occurs when primary is up if to make a test configure on FW side a wrong primary address so that the primary IKEv2 fails the remote does not accepts negotiation on its secondary outside because its own primary is still alive.
Hope to help
Giuseppe
10-04-2024 12:43 AM
Show ip nhrp nhs detail
show dmvpn detail
debug dmvpn detail all
MHM
10-11-2024 12:17 AM
Do you have access to Hub Router, only you have access to spoke ?
if you have only Spoke, then you need to co-ordinate other side Hub side to get some Logs.
10-03-2024 11:20 AM
Thanks for your answer and support! much appreciated!
10-10-2024 01:33 AM
10-10-2024 02:47 AM
I ask you before these debug, please share it
show dmvpn detail
10-10-2024 03:05 AM
10-10-2024 03:13 AM
1 xx.xx1.206 10.126.160.1 IKE 00:29:48 S 10.126.160.1/32
1 xx.xx1.207 10.126.160.2 NHRP 00:29:51 S 10.126.160.2/32
These inform me that there are two Hub in in your DMVPN
one stop in IKE and other in NHRP
there is req send 3250 and only 99 reply
10.126.160.1 E NBMA Address: xx.xx1.206 priority = 0 cluster = 0 req-sent 3250 req-failed 3 repl-recv 99 (00:30:28 ago)
10.126.160.2 E NBMA Address: xx.xx1.207 priority = 0 cluster = 0 req-sent 3250 req-failed 3 repl-recv 99 (00:30:28 ago)
Can I see Spoke tunnel config ?
MHM
10-10-2024 03:18 AM
interface Tunnel10
bandwidth 5000
ip address 10.126.189.159 255.255.224.0
no ip redirects
no ip proxy-arp
ip mtu 1300
ip nat outside
ip nhrp authentication Pit10
ip nhrp network-id 101261600
ip nhrp nhs 10.126.160.1 nbma xx.xx.1.206
ip nhrp nhs 10.126.160.2 nbma xx.xx.1.207
zone-member security DMVPN
ip tcp adjust-mss 1260
load-interval 30
if-state nhrp
qos pre-classify
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
tunnel key xxxxxxxx
tunnel protection ipsec profile IPSEC-PROFILE ikev2-profile IKE2-CERT-PROFILE
10-10-2024 03:23 AM
1 xx.xx1.206 10.126.160.1 IKE 00:29:48 S 10.126.160.1/32 <<-
ip nhrp nhs 10.126.160.1 nbma xx.xx.1.206 <<- remove this Hub
and check
NV-36200-WAN1#show dmvpn detail <<- this must show statc UP for Hub .207
MHM
10-10-2024 03:30 AM
Interface Tunnel10 is up/down, Addr. is 10.126.189.159, VRF "global"
Tunnel Src./Dest. addr: 10.0.0.10/Multipoint, Tunnel VRF "global"
Protocol/Transport: "multi-GRE/IP", Protect "IPSEC-PROFILE"
Interface State Control: Enabled
nhrp event-publisher : Disabled
IPv4 NHS:
Type:Spoke, Total NBMA Peers (v4/v6): 1
# Ent Peer NBMA Addr Peer Tunnel Add State UpDn Tm Attrb Target Network
1 xx.xx1.207 10.126.160.2 IKE 00:57:43 S 10.126.160.2/32
Crypto Session Details:
Interface: Tunnel10
Session: [0xFFFF5A54E3B0]
Crypto Session Status: DOWN
fvrf: (none), IPSEC FLOW: permit 47 host 10.0.0.10 host xx.xx1.207
Active SAs: 0, origin: crypto map
Inbound: #pkts dec'ed 21668 drop 0 life (KB/Sec) 0/0
Outbound: #pkts enc'ed 484 drop 72 life (KB/Sec) 0/0
Outbound SPI : 0x 0, transform :
still down. useful information could be that the connection is restored for 20 -30 min every 4 hours
