Low Latency Router
Vivek Agarwal
We are having 10 mbps point to point dedicated leased line between 2 locations. We need a router which gives least latency.
Our data flow is latency sensitive and each microsecond matters to us. Kindly suggest a router which will minimize the latency to the maximum.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Hmm, an interesting requirement, as I don't recall generally seeing router latency performance documented.  Generally, the biggest factor for increasing latency would be if there's any queuing latency, which the device doesn't have any control over, beyond perhaps dropping rather than queuing packets.
In theory, a router doing MPLS switching might offer less latency than a router doing fast path routing.
I don't know whether any "routers" would support it, or even L3 switches, if "routing", but if your 10 Mbps p2p was Ethernet, bridging it, at L2, would allow some devices to use cut through switching.  That can save some latency.
