LSA operation
skazeem96
I have a question to understand please clarify me.
In the flow chart, which i have attached if the sequence no is higher, go to “A”.
when “sequence no” become higher ( increment)?
Up to my understanding,
1.when there is a change in OSPF network.
2.By default, each OSPF LSA will send LSU for every 30 minutes.
Even though there is no change in the network,after 30 mins time expire (default), "DRother" will send LSU with “sequence no” increment to DR and BDR.
With this, DR will consider there is a change in a network by seeing the “sequence no” increment in LSU sent by DRother. Now in DR,with respective to flow chart, it has to go to “A”.
my questions:
1.why it needs to go ”A” when there is no change in the network?
2.why sequence number should increase when there is no change in a network?
3.In the flow chart, " Is sequence no same" if yes ignore LSA. when will this scenario happen ?
4. In the flow chart, " Is sequence no  higher" if "No"  send LSU with newer information to the source. when will this scenario happen ?
rais
Level 7
Level 7
For the 4. above, as soon as the originating router gets an LSA with it's own IP as originator it [the router] comes to know there is some stale information in the network that might have been originated by itself before it was last powered-up. It will start the process to clear this stale info.
HTH.
