Major Alarm decode on 12406 GSR
sumanth_myneni
Slot # Card Specifc Leds
17 MBUS-OK
18 MBUS-OK
19 MBUS-OK
20 MBUS-OK
24 MBUS-OK MAJOR-ALM MINOR-ALM
25 MBUS-OK MAJOR-ALM MINOR-ALM
28 BLOWER-OK
SLOT 24 (PS A1 ): Standard AC PS(s) + Powershelf Alarm Module(6)
MAIN: type 15, 800-12098-01 rev D0
Deviation: 0
HW config: 0x00 SW key: 00-00-00
PCA: 73-5704-02 rev C0 ver 2
Design Release 1.0 S/N SAL09211N5D
MBUS: MBUS Agent (1) 73-2146-07 rev B0 dev 0
HW version 1.2 S/N SAL09190G2D
Test hist: 0x00 RMA#: 00-00-00 RMA hist: 0x00
DIAG: Test count: 0x00000000 Test results: 0x00000000
FRU: Linecard/Module: GSR6-ALRM=
FRU: PEM1: PWR-GSR6-AC=
FRU: PEM2: PWR-GSR6-AC=
MBUS Agent Software version 1.99 (RAM) (ROM version is 2.42)
SLOT 25 (PS A2 ): Standard AC PS(s) + Powershelf Alarm Module(6)
Deviation: 0
Design Release 1.0 S/N SAL09211N50
HW version 1.2 S/N SAL09190G7U
Can some one help me on what the Alarm Minor and Major specify in this context on a 12406 GSR?
umedryk
Level 5
Level 5
The alarm leds on the alarm cards in the GSR chassis have only very limited meaning and can be ignored. If there is any minor, major or critical alarm on the router this will be signalled with appropriate logging messages, which should be used as indicators instead of leds. This can be cleared by the following command:
Router# clear facility-alarm environment
