Managed Switch
ltwalling
What Cisco managed switch models in the 12-48 port range support port rate settings down to 64kbps, and also in addition to this, what units support intelligent traffic shaping functions? Preferably a unit including some type of GUI would be useful for the above applications also.
Thanks.
royalblues
Level 10
Level 10
The low end 2960 switches are capable of doing advanced qos like rate limiting the traffic to 64kbps and other traffic shaping functions as well.
It can be accessed via a HTTP interface as well
It is available in 8, 24 and 48 ports models
http://www.cisco.com/en/US/products/ps6406/products_data_sheet0900aecd80322c0c.html
Narayan
Do they support this on ingress and egress?
Thanks.
It looks like the 2960 series only supports rate limiting down to 1mbps, making it inadequate for the application.
The next model range up seems to be more suitable.
