Routing
Labels
as we know, when doing mutual redistribution with two or more routers, there will be loop if we don't use tag on one redistributing router and block the route learn back on the other. however, even without configuring tagging and blocking, IOS XE and...
daniel ng by Level 1
  • 306 Views
  • 6 replies
in IOS XR, when you configure BFD in static route, there is multihop option as in 'bfd fast-detect multihop <source address>' however you can't configure destination as we can in IOS XE. the router uses the directly connected neighbor interface addre...
  • 234 Views
  • 1 replies
  • 1 Helpful votes
My Cisco router has gone into continuous boot loop. Not able to enter ROMMON either.Can someone please help me?Product: Cisco ISR 1100 – C1111-4PROMMON Version: 16.12(1r)IOS Image: c1100-universalk9.17.12.x.SPA.binIssue Type: Boot loop / unrecoverabl...
p1990 by Level 1
  • 299 Views
  • 11 replies
Trying to get into the C1111-4P router after powering on it can't find the IOS image and also I cannot get into ROMMON mode can you help please thank you:Rom image verified correctlySystem Bootstrap, Version 16.9(1r), RELEASE SOFTWARECopyright (c) 19...
I have a nexus switch 93180YC-EX.I'm getting below warning syslog message:%TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded! (message repeated 1 time)When I checked the resources usage, ...
Sagar4 by Level 1
  • 731 Views
  • 2 replies
Good day,I have a quick question I have a cisco C3548P that I am trying see why NAT isn't working.  The incoming interface is eth1/46 which has ip nat inside on it.  The outgoing interface is Vlan2799 and has ip nat outside, This vlan does BGP peerin...
wgranada by Level 1
  • 309 Views
  • 5 replies
An OSPF router has 3 directly connected networks; 172.16.0.0/16, 172.16.1.0/16 and 172.16.2.0/16  Which OSPF network command would advertise only the 172.16.1.0 network to neighbors?    A. rtr(config-router)# network 172.16.1.0 0.0.255.255 area 0    ...
Jaylene by Level 1
  • 4119 Views
  • 8 replies
  • 1 Helpful votes
Hi,I work for an ISP which, like many others and amongst other things, provides fixed/dedicated public IPs via 1to1 static NAT through a Cisco Firepower ASA FW.I've had a customer of ours reporting the following recently:"The issue: We are seeing TCP...
mickpro77 by Level 1
  • 203 Views
  • 0 replies
