07-18-2013 07:03 PM - edited 03-04-2019 08:29 PM
Hi Team,
I want to know maximum bandwidth perfomance in Cisco 4451-X Integrated Services Routers.
is it reliable for Service Provider ??. and support 4 byte ASN for BGP ?
Thanks in ADV,
Solved! Go to Solution.
07-19-2013 02:54 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Q. What are the key new features and changes that are being introduced in the Cisco 4451-X?
A. The Cisco 4451-X offers:
• Default forwarding bandwidth of 1 Gbps upgradable to 2 Gbps with a software-activated upgrade license
Reliable for SP? Rather early to tell, as it's so new. Probably as good as other ISRs.
4 byte ASN? Don't know, but likely it does. Doubtful a new router, with current IOS, would not.
07-19-2013 02:54 AM
Disclaimer
Posting
07-19-2013 08:18 PM
Hi Joseph,
Thanks for info.
Upgradable to 2Gbps with a software-activated upgrade license means latest IOS, not any hardware require ? am i right ?
Pl clear me for the same.
Thanks for insight.
07-20-2013 03:36 AM
Disclaimer
Posting
Yes, software license upgrade appears to be all you need. (Seems similar to one of the ASR1Ks, i.e. software license performance upgrades.)
