Memory leaking
punit.dixit
Dear All,
We have seen memory leaking in Cisco devices.The reason could be Bug on IOS & as workaround Reboot to free dead cells and add in free pool.
Can you share does Cisco have any procedure to release unused dead memory to free pool manually without reboot.
Address Blocks & process details holding memory is available through commands :
show memory debug leaks
show memory debug leaks summary
Rgds
Rozsa Illes
Hello Punit,
Unfortunately, there is no other workaround but to reload the router.
A few other useful commands and tips can be found on this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6f3a.shtml
Rose
Hi, there is no such ability, but you can also use:
memory sanity all
scheduler heapcheck process memory io (processor, pci, etc.)
sometimes it can be helpful
Ñnate
Most likely a bug. Exclude polling of the CISCO-PROCESS-MIB using an SNMP view.
Joseph W. Doherty
In theory, if you can identify the process that has allocated the memory it's no longer using, and if there is a way to stop and restart that process, that should return the memory to the free pool. However, if that memory is highly fragmented, even though the memory is available, it may not be useful (i.e. if it's in too small fragments), and so a reload will likely still be needed.
