memory process allocated to ACLs
echelon360
ISR 2811
I have several ACLs running on this router. Is there a way i can gather stats to see how much of resources the router is assigning to these ACLs?
thanks!
Giuseppe Larosa
Hello Clive,
try with
sh proc mem | inc ACL
85 0 196 196 6972 0 0 TurboACL
86 0 196 196 6972 0 0 TurboACL chunk
188 0 54628 9188 70804 0 0 Crypto ACL
I did this in a C2811 with c2800nm-adventerprisek9-mz.124-7a.bin
use the command without the type to understand the meaning of each column
Hope to help
Giuseppe
thanks Giuseppe! Appreciate your responses.
I had a look in detail on this and from what i understand, i think it requires the TurboACL feature to be enabled (access-list compiled) before it is active on the router.
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_a2.html#wp1061456
