Memory Upgrade
cgeorgiev
Upgrading the memory on an 1841.
After inserting a 256MB/PC133/SDRAM/DIMM it would not post during the boot, hangs.
If i take out the chip it works fine.
The on-board memory is 128, so the 256 is the max it would take to a total of 384. According to the documentation this should work.
The memory chip is a Transcend chip, basically Samsung...same as the internal memory.
My question is, would the router reject a GOOD memory chip for any reason?
hobbe
Level 7
Level 7
Is it an original memory that is supposed to be in that type of cisco router ?
if not then that is most likely your problem.
they (the router) can be very fuzzy about what hardware they use.
Good luck
Leo Laohoo
The connectors could be dirty (we had a few like that).  Wipe it down or use compressed air and check.
