Method to achieve DMVPN dynamic routing to spoke external IP w/o using default route?
Joseph W. Doherty
Working to replace hub-and-spoke (router-to-router) individual VPN tunnels (GRE/IPSec or VTI) with DMVPN but without using default-route.  Default-route doesn't lead to the next-hop the hub should use for  spokes.  With individual tunnels, had individual statics for each spoke.
I know what the next hop should be for spokes; trying to determine if there's any way to leverage what's in the NHRP cache to direct external IPs in it to the next hop.
Anyone solved this or have suggestions?
5 Replies 5
Marwan ALshawi
So what you trying to achieve or improve ?
The spoke in anyway will register with hub either it is static or dynamic ip
If you have route to reach
Each of the
Hub and spokes and igp over the DMVPN cloud then should work even without default route if u do not need it
"So what you trying to achieve or improve ?"
No "touch" hub configuration as spokes are added or withdrawn.
Support for spokes using dynamic external IP addresses.
"If you have route to reach
Each of the . . ."
Yes, within the IGP routing is fine, issue is, external tunnel endpoints need to be routable too.  If you have explicitly defined routes for the external spoke tunnel IPs, then its something that has to be "touched" on the hub, also unable to define a static if I don't know what the spoke's tunnel IP is (i.e. is dynamic).
PS:
Four possible approaches I've been looking at, if unable to take direct advantage of the NHRP cache, include:
Some form of PBR.  Haven't figured out a way, if there is one, to utilize it.
Dynamic VTI rather than DMVPN.  This might work but Cisco's documentation is a bit sparse.
Placing the DMVPN routing into a different VRF.  Should allow me have a dedicated default route for this VRF, but then need to redistribute routes between VRFs (two way because will have two hubs).
Since OSPF is IGP, also considered using different area, but topology wouldn't easily support ABRs where needed.
Hi Joseph
In this case use the BFF option
But the answer here about how you can have simple defulte ruting in the HUD just for tunnel establishments with spokes is
By using the commandbtunnel vrf this cammon will let the tunnel use the specified vrf to reach the other end of the tunnel
Example int tunnel 0
Ip vrf forwarding red
Tunnel vrf blue
Int x/x
Description interface to Internet
Ip vrf forwarding blue
Ip route vrf blue 0.0.0.0 0.0.0.0
The tunnel will participate In the routing and fib of vrf red while it will use vrf blue routing table to reach the other end of the tunnel
Ini other word youl be using somthing called front end tunnel where you can leave the tunnel in the router golba routing and let it use a vrf assigned to the router external interface for tunnel estsblishment
Reading your post, and thinking about what you describe, VRF might be the solution I need while avoiding the need for mutual redistribution.  I'll try it and let you know whether what you proposed works.
PS:
What's "BFF option"?
VRF was needed, with its own default route.  Didn't need to user another VRF for the inside interface, global (the default) was all that was needed.
Although an external facing VRF was one of the key parts of the solution, couldn't get it to work.  Didn't realize it as the time, but what was needed was DMVPM using VRF aware IPSec with fVRF.  Unfortunately, none of the "cookbook" examples I found for such solutions worked.  However, by trial and error, did find a working solution.
In my case, what was needed included:
ip vrf Internet
rd 1:1
crypto keyring DMVPN vrf Internet
  local-address GigabitEthernet0/0
  pre-shared-key address 0.0.0.0 0.0.0.0 key aKey
crypto isakmp policy 10
authentication pre-share
crypto isakmp profile DMVPN
   keyring DMVPN
   match identity address 0.0.0.0 Internet
crypto ipsec transform-set DMVPN esp-aes 256 esp-sha-hmac
mode transport
crypto ipsec profile DMVPN
set transform-set DMVPN
interface Tunnel1
tunnel vrf Internet
tunnel protection ipsec profile DMVPN
interface GigabitEthernet0/0
ip vrf forwarding Internet
ip route vrf Internet 0.0.0.0 0.0.0.0
