metro ethernet link increased
devonevans
Hello-
quick question.  we had one of our links (metro-ethernet) between our main and remote site upgraded from 4mb to 8mb but we still seem to be only getting 4mb.  Is there anything else on our end that needs to be done?  Thanks for any help.
-Marc
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Normally no, but if you have policing or shaping enabled you need to adjust for the higher rate.
It's also possible the MetroEthernet provider didn't implement the upgrade correctly.
Lastly, it's also possible however you're testing for the increased bandwidth it self limits itself, e.g. client whose TCP RWIN is too small.
we're not doing any shaping or anything so its either them or the test we're using.  thank you much!
