Mgre help into EIGRP
CiscoAmd
I'm having trouble with mgre configuration of a spoke using point-to-point gre and a hub router, EIGRP does not seem to work and does not show in routing table for r7 and have it ping to r12 through mgre. Note: There are other routes for Hub router at are also not working, but want to focus on int Tunnel0 for mgre. No static routes can be used, so I'm not sure why it's not working as I followed the guide from https://community.cisco.com/t5/security-knowledge-base/mgre/ta-p/3115315
R12 configuration (spoke):
Router#show run
Building configuration...
Current configuration : 3489 bytes
! Last configuration change at 18:04:46 UTC Wed Feb 21 2024
version 15.9
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
redundancy
interface Loopback1
ip address 192.168.127.12 255.255.255.255
interface Loopback2
ip address 22.22.22.22 255.255.255.0
interface Tunnel0
ip address 192.168.5.12 255.255.255.0  //tunnel to R5 hub
tunnel source GigabitEthernet0/1
tunnel destination 172.16.30.5
interface Tunnel1
ip address 192.168.3.12 255.255.255.0
tunnel destination 172.16.30.3
interface GigabitEthernet0/1
ip address 172.16.30.12 255.255.255.0
duplex auto
speed auto
media-type rj45
router eigrp 100
network 22.22.22.0 0.0.0.255
network 192.168.3.0
network 192.168.5.0  //network added from tunnel int for eigrp 100
network 192.168.127.12 0.0.0.0
R5 configuration (HUB):
R5#show run
Current configuration : 4008 bytes
! Last configuration change at 13:04:35 CDT Wed Feb 21 2024
version 15.9
hostname R5
boot-start-marker
boot-end-marker
logging buffered 70000
no logging console
no aaa new-model
clock timezone CDT -5 0
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
no ip address
interface Loopback1
ip address 192.168.127.5 255.255.255.255
interface Tunnel0
ip address 192.168.5.5 255.255.255.0
no ip redirects
no ip split-horizon eigrp 100
ip nhrp map 192.168.5.12 172.16.30.12 //r12 tunnel and map
ip nhrp map 192.168.5.11 172.16.30.11
ip nhrp map 192.168.5.4 172.16.30.4
ip nhrp map multicast 172.16.30.12 //r12 map
ip nhrp map multicast 172.16.30.11
ip nhrp map multicast 172.16.30.4
tunnel mode gre multipoint
interface GigabitEthernet0/0
ip address 177.7.7.5 255.255.255.192
duplex auto
speed auto
media-type rj45
ip address 172.16.30.5 255.255.255.0
duplex auto
speed auto
media-type rj45
router eigrp 100
network 177.7.7.0 0.0.0.63
network 192.168.5.0
network 192.168.127.5 0.0.0.0
R7 configuration: Only interfaces are configured and eigrp 100 only
R7#sh run
Current configuration : 3237 bytes
! Last configuration change at 12:48:41 CDT Wed Feb 21 2024
version 15.9
hostname R7
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
no ip address
interface Loopback1
ip address 192.168.127.7 255.255.255.255
ip address 177.7.7.7 255.255.255.192
duplex auto
speed auto
media-type rj45
ip address 177.7.7.137 255.255.255.192
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
media-type rj45
router eigrp 100
network 177.7.7.128 0.0.0.63
network 192.168.127.7 0.0.0.0
Giuseppe Larosa
Hello @CiscoAmd ,
on hub router you should map multicast to the WAN address of the spoke not to the address on the GRE tunnel
int tunnel 0
ip nhrp map multicast 192.168.5.12
check with
show ip eigrp neig
Hope to help
Giuseppe
spoke use p2p gre and hub use mgre ?
this not work you need to config p2p gre in hub
mgre is build upon the detect of NHRP and as I see you not run the NHRP in spoke tunnel
MHM
