Migration from ATM to Ethernet
Adeel Hasany
Hi All
We are trying to Migrate the our customer circuits from ATM interface to Ethernet without minimal disruption. We have around 20 odd customers
hanging off the that ATM interface, each sub interface is for each circuit. What will be the best migration strategy to transfer them over onto Ethernet PE from ATM PE.
Ad
Reza Sharifi
You can build the interfaces, deploy IP addresses and do all the other prep work ahead of time. Have a maintenance window for each customer and than move one customer at the time during each window from ATM to Ethernet. You should also have a backup plan just in case.
Hi Reza,
Thanks I am actually looking for a solution infact.. I need a solution to migrate customer off from ATM to Ethernet. any idea how can that be possible.
Ad
