Minimum IOS Version to run BGP?
adamdaviddoyle
What is the minimum IOS version to run BGP.
We have 1750's, 1751's, and 1841's.
Thank you for your help
Adam
c.thomsen
Hi Adam,
it is more important to know - the correct feature set..
since cisco using the new IOS packing (12.3) => your min choice is SP Services...
Christian Thomsen
CCNP
Also consider that running older versions of IOS might leave you open to various BGP based DOS attacks.
What would be the minimum IOS version you would reccomend? i currently have at least 12.0 on about 100 Routers.
Hi Adam,
the easiest way to find the right IOS is 2 use the feature navigator:
http://www.cisco.com/go/fn
regards
CHristian
